Bad seat back tables.
We were all there, in the great Northern Rail seat discussion - the one where we all decided on a more padded seat and got ignored !
This is designed to be a more general discussion on seat back tables.
For example, the refurbished 158's on Northern. Acceptable seats (although not better than the ones they replaced, but we'll park that one)
But the seat back tables leave a lot to bd desired. A flat piece of metal with no sort of lip to stop your coffee flying off across the carriage. Is this the best they could come up with ?
Look forward to other examples of bad seatback design !
py_megapixel
5 Nov 2018
Northern England
Two come to mind
- Class 196. Just uselessly small. I struggled to fit a sandwich and a bag of crisps on it, let alone a laptop
- Class 377. The first time I travelled on one I tried to pull down the table and it made such a loud screeching noise that I felt like the whole carriage was looking. Southern would do well to invest in a large quantity of WD40.
The Avanti/Lumo seats have the same issue. I quite like the Fainsa Sophia's table, it has a coffee recess and is extendable for a laptop.
Yes, I quite like the Pendo's but I've noticed this issue with them as well.
fbm99
8 Jun 2025
Lincoln
I’ve always found the Chapman seatback tables (as fitted to a lot of 156s and 170s etc) to be pretty poor, been on a few trains where they’ve been on a slant so you don’t want to put hot drinks on there.
milooo
3 Dec 2024
Stevenage
Two come to mind
That reminds me of a 700s seat back tables nearly made me deaf!
Oh yes, I know the ones !
fgwrich
15 Apr 2009
Hampshire
I find the metal ones slightly better than the rubber ones, but when it came to sprinters you were lucky if you had one at all in some. I think Anglia & East Midlands removed theirs in the 153s.
And you’ll always notice it when ex FNW 150207 turns up on the GW compared to a native, not just for the seat layout but lack of seatback tables, despite being the same chapmans.
fbm99
8 Jun 2025
Lincoln
I was gonna say, EMT removed theirs on the 153s and I think some of the 156s as well. There was an ex FGW 153 (153372) with EMT for a bit which actually had tables, but I think the seats were a different model.
fgwrich
15 Apr 2009
Hampshire
Indeed, going back a bit here but when First Great Western inherited its fleet of Class 153s from Wessex, all but two (329/369) had the original BR Class 158 seats in them - Not Wessex Trains finest idea that given how low down they were! First Great Western then refurbished all bar 329/369 and later inherited 361 with Richmond seats freed up from ScotRail’s Inverness refurbishment. A controversial choice to some but I rather like them, and ScotRail and TFW have both kept them!
329/361/369 All had the pretty standard Chapman seats installed by Central & First North Western.
Russel
30 Jun 2022
Lichfield
It does make a bit of a mockery of the buffet putting hot drinks in paper bags to carry them back to your seat so you don't scald anyone else, only for the drink to slide off the table as soon as you get back to your seat!
superalbs
Verified Rep - Superalbs Travels
3 Jul 2014
Kraków
I believe Anglia also removed the armrests for some reason!
Shimbleshanks
2 Jan 2012
Purley
It must be an age thing, or maybe I do a lot more work on the move these days, but I find availability of a table and its quality the single most important factor in rating the quality of train interiors. I had a rather uncomfortable journey back from Liverpool the other day on a LNW Cl350, trying to balance my not particularly big laptop on the seatback table, though their provision of 'proper' tables is quite generous. Just couldn't get one on that particular occasion. Maybe I should get an even smaller laptop.
dk1
2 Oct 2009
East Anglia
Seat back tables on the GA class 745/755 fleet seem absolutely perfect but then that’s a reoccurring theme about most things with those trains.
Parallel
9 Dec 2013
I always found the Richmond seats rather comfortable, IF the base cushion was of appropriate height. If it had been condensed, the curve of the back cushion is positioned in the wrong place which is rather uncomfortable.
I quite like the seat back tables of the Richmond seats too.
Whilst the seats themselves are not bad, the seat back tables are awful on the Avanti 807s and the Lumo trains. The table has only been designed for laptops, so you have the pull out ridge 2/3 of the way back, and no groove for hot drinks which mean they can just slide off the tables when going around curves. Very poorly designed in my opinion.
The seat back tables on GWR’s IETs and LNER’s Azumas are better, but the seats themselves are dreadful.
The seat back tables on the back of the GWR 158 BR seating are also bad, since new cushions with extra padding have been installed, the tables fold out too low down. They are also very flimsy.
The Chapman seat tables are also awful, but they mostly run short distance services so they are not bad.
The tables on the back of the HST and TfW 158 seats are very good. They have a pull out support for laptops, and a groove for drinks.
LowLevel
26 Oct 2013
The 153s at EMT had a mix of suburban and long distance Chapman shells. The ex Central ones which pre 170 spent a lot of time bolted on to 158s etc on long distance work had arm rests and tables.
The reseated units had a motley collection of shells that were mostly tableless but 311 and I think 326 also came without arm rests to boot.
There was no concerted decision to remove the tables, the mix was there until they were all withdrawn.
nilvaj395
11 Oct 2025
This has always been a benefit to the SR units, even though they are ironing board seats they have much better seatback tables.
Class83
8 Jun 2012
The 350/2s often used on that route don't even have tables or seatback ones. Along with 5 across seating for an InterCity experience.
Starmill
18 May 2012
Bolton
They really were a shocking unit for a Birmingham - Liverpool journey it has to be said.
DelW
15 Jan 2015
Though down here in South Western land we're told off for complaining about the high proportion of 3+2 450s on London to Portsmouth services :s
The Desiros' seat-back tables have lasted well - they're around 20 years old now, yet it's very rare to encounter a broken or missing folding table. But of course they're only available in the 2-wide airline seats, nothing in the 3-wide facing bays.
And of course, any seatback table is better than none at all (yes, this means you, Thameslink).
RunRepeat
13 Jun 2018
I must say, I find them too small and too high up the seat back, especially if tryng to use a laptop. It's the only part of my experince with these fantastic units that iritates me!
dk1
2 Oct 2009
East Anglia
Fair enough. Must say I’ve never tried to use a laptop on one of those before and don’t even own one anymore.
