AWS UkSpt.dll plugin doesn't work on some routes
altavista
19 Jan 2013
It's mainly a problem with this sprinter plugin on the Network West Midlands. The diesels and electrics work fine with the UKdt.dll plugin but the AWS and the DRA doesn't work with the DMU's. The AWS sunflower stays lit and the DRA stays lit. When I move the reverser nothing happens.
I am using the latest OpenBVE with Network West Midlands running on Arch Linux through the latest Wine. Game works better through wine than directly through mono or installing OpenBVE via package manager.
Thanks for any help.
Wim G.P.R
7 Aug 2006
CARDIFF
Well the dmu plugin does have a problem when you run a dmu on a route for a loco.
In that the brakes will not release.
The way around that is to open and shut the doors.
This effects all dmu's that use the UkSpt plugin.
What you seem to be having may be a Linux problem.
I use Windows 7 and also have used XP and Vista.
I've never had the other problems you discribe.
altavista
19 Jan 2013
thanks
I'm not sure it is a Linux problem. On some other NWM routes, the sprinter plugin works fine.
For example the 17:51 whitminster-radley route works but others don't
Is there something I can check in the route file?
