petethetim
Yes folks my latest activity should be available with in the next 24 hrs for download & its a first for me.
I have picked the Bristol to Cardiff route & set the activity in the Summer of 1972.
Cardiff Central to Paddington (Limited Stopper)
Set in the summer of 1972, you are in Charge of the Cardiff to London Paddington service, you will make limited stops & you will hand over the train when you get to Bristol Temple Meads Thus ending the activity.
You will see a few Golden Oldies during this run including The BR Prototype Falcon & Hymek's are still in abundance.
I feel this is my best BR blue Activity yet and really recalls the heydays of BR
The Following classes of Locomotive can be seen
24,25,31,35,37,40,45, & 50's plus various DMUs, It is a 1970's train spotters Paradise.
Only Download this if you think your machine will handle it as It is quite intensive at points along the run & it uses some of the very latest BR Blue stock Available from UKTS
I recommend the use of the MSTS bin Patch as the amount of AI traffic makes this quite demanding in places
I also would recommend that ALL my activities are played with the Alerter switched on as this adds to the overall realistic effect of the simulation
The alerter is turned on by Hold the Ctrl key & press 4 on The Number Key Pad at same time, repeat to turn off
