Hi,
Just looking for some clarification regarding permissive movements.
Scenario
A signal displays an associated position light (APL) with a junction indicator for a permissive movement onto a diverging line.
Beyond the signal and prior to the cross-over points there is a ground position light (GPL) signal.
My query is how far is the initial movement authorised?
Ofcourse I would obey the GPL and never assume it's clear and processed at caution stopping short or any obstruction etc.
However, given that the initial signal has an APL and a Junction Indicator - I would assume thats telling us the route for which the movement has been set so ordinarily the following GPL would be OFF?
What are your views on this - any input would be appreciated.
Thanks
Scenario
Thanks
CO531 to say P6 occupied, will be one signalled route as far as the box is concerned, CO531 will be a two whites with 6, and the GPL in the middle of the route will show two whites and a 6. If P6 was clear, then CO531 would be SY and '6' with the GPL showing two whites and a 6.
