Artemis II and other space launches
The Pelican
3 Oct 2025
The Artemis II launch is in progress, NASA's first manned journey to lunar orbit since Apollo in the 1970s.
Anyone who has played Kerbal Space Program will realise that a lunar flyby is an interesting challenge- the game is a spaceflight simulator based on a 1:10 solar system. First you launch your rocket and put your spacecraft in an Earth orbit, then do a burn to move into a transfer orbit, then circularise around the moon, then the reverse to return- it's not too difficult. It removes the risks and difficulties of lunar landing. But NASA have chosen a "free return trajectory" for this particular flight, which avoids the need to do a burn in lunar orbit.
Artemis I did this flight without astronauts and returned safely.
It is interesting to compare Apollo and the Saturn Five, the Space Shuttle and the International Space Station, and the Orion, Crew Dragon and Starliner manned capsules and the SLS/ Falcon rockets, perhaps Starship in a few more years, as the products of different eras of space technology.
JamesT
25 Feb 2015
It did look quite impressive taking off. It’s just a shame that SLS seems such a backwards step. Taking the engines that were reusable on the space shuttle and expending them for every launch. When Falcon has been showing how to do reusable rockets for about a decade now.
Cloud Strife
25 Feb 2014
I can explain this. Basically, the Space Shuttle and Falcon can reuse the engines because they only needed to send the payload to low earth orbit. So, the rockets didn't need to go so far or so fast, and it's also much easier to retrieve/reuse them. On the other hand, retrieving SLS would be massively more difficult because of the sheer size of it, and it needs to be that size so that they can send as much cargo as possible towards the Moon.
The general principle is that reusable engines are doable for LEO, but deep space requires much more power. Starship will apparently deal with this by having a refuelling station in space, but a lot of aerospace engineers are very cynical about the chances of Starship actually working in the way that Elon says it will. I suspect that Starship will end up being like the Space Shuttle: great technology, but nowhere near what was promised, especially the idea of the fuel tanker in space.
From what I've been able to piece together, NASA are adopting the attitude that they're very open to Starship, but only if it proves itself. Until then, they'll continue with tried and tested technology for the purpose of going to the Moon, as they simply can't afford yet another loss of astronauts. If there's a third disaster, then it would pretty much rule out any more involvement with NASA sending humans into anything more than orbit around Earth.
Peter Mugridge
8 Apr 2010
Epsom
There's an excellent visual representation of the position of the craft relative to both Earth and Moon here:
( No quote because it's visual only but with an added box showing current distances from both and the craft's speed relative to Earth )
The Pelican
3 Oct 2025
The trackers are very impressive, I've found this 2D one from Canada- one of the astronauts is being sent by the Canadian space agency.
The Heavens Above 3D one is great, and looks a lot like the Kerbal Space Program user view while looking at the spacecraft.
It also seems to deal with some issues the 2D view produces- it looked from the 2D view like the insertion burn into the transfer orbit completely reversed the direction the capsule was orbiting, which I don't think actually happened, but was an artifact of compressing a 3D planet into 2D.
JamesT
25 Feb 2015
Musk’s roadster was put into an orbit that might reach Mars using a Falcon Heavy, which is effectively three Falcon 9’s strapped together. Two of the three made it back to land safely.
There were a lot of engineers who were sceptical about reusable rockets full stop.
Earth orbit rendezvous was one of the options considered for Apollo and it was the profile chosen for Constellation before that was cancelled. It’s not a completely wacky idea. NASA also need it to work given that Starship is the chosen lander for the Artemis programme.
The Pelican
3 Oct 2025
Nasa are launching Artemis III in 2027- it will dock to the Blue Moon Lunar module (Blue Origin's moon lander) and a SpaceX Starship, representing the Starship-based HLS, or Human Landing System. This mission will help measure whether the two private space companies are able to deliver their vehicles in time. Eventually, the HLS will be refulled for each flight by up to 12 Starships launching from Earth and filling up a tanker, another vehicle based on Starship, which in turn will fill up the HLS.
Wikipedia: (https://en.wikipedia.org/wiki/Artemis_III)
The Pelican
3 Oct 2025
Starship is doing it's first orbital test flight today- the parabolic path these launches normally follow (from Texas to the Indian Ocean) will have a short extra burn to put it into orbit breifly. This is Starship Flight 14. This is important for future Artemis flights because the Artemis program's lunar lander, HLS (Human Landing System) is an adapted Starship that will refuel in Earth orbit from tanker which are also adapted Starships.
EYFanatic
29 Sep 2025
Hell's Dungeon
Well, to be more exact... It is going for 10 hours in orbit which means about 6 orbits or so. As I understand it, from looking at the technical pieces published, its going on a standard suborbital launch and only then if everything looks good will it go for orbit ops and burn. No catch of booster or starship this time, but if all goes well the next will be caught both booster and ship which should be a technical milestone.
Also, some of IFT13's tiles are being reused in non critical areas for testing purposes
Update:
Booster lost at least one engine on launch and then two on boost back and landing. The Starship lost an RVac on the way to orbit and the team elected to then/now decide to leave it in the suborbit and land in the Indian Ocean
Update 2:
After looking at data and video footage, SpaceX decided to override the onboard systems and reset it to fire the engine to boost into orbit anyway and the mission will now resume orbit ops and deploy the payload of Starlinks
I love the fact they basically saw an issue, voted it out and then somebody went "We're not sure its too much of an issue... Sod it, lets go for it anyway" and got it 2km higher then they expected
