Arriva Rail - DMI
J05h1
17 Oct 2017
Hi all,
I have my final interview coming up next week and I'm just after a little help on what sort of things I'm likely to be asked.
I've been told that it's pretty much the same as the MMI interview but less intense and they ask you a few questions about the company. Does this sound about right?
Any help would be greatly appreciated.
Many thanks.
paepo
28 Jun 2015
No experience of Arriva but my experience was that the DMI was much more intense than the MMI.
The 2 interviewers were nicer than pie to begin with and then switched into a good cop/bad cop routine and then were fine then did it again and kept trying to pick fault with any answer I gave and 1 was deliberately talking in an aggressive manner and talking over me. It's all an act to see how you react to pressure and I guess for the possibility of dealing with aggressive customers. He was convincing though, as I still think of him as an ar$ehole for that 45mins I had to endure!:lol:
I passed, all I can say is have confidence in the answers you give and don't let them try to sway you if they start picking at your responses. Don't get flustered if they try to be aggressive in their questioning or talk over you or cut you off as you're answering.
That's all I can advise as no doubt you'll have trawled this site and already have all the questions you're bound to be asked noted down.
You may not encounter managers like I did that day but incase you do at least you know it may happen.
All the best, hope you ace the interview!
J05h1
17 Oct 2017
Thanks Paepo for sharing your experience. I made note of things you mentioned. I will try my best of best . once again thank you I really appreciate it.
Daly131
27 Feb 2017
Good luck mate hope it works out for you.... did u have to pass the vse before this?? I have it on friday, any tips??
J05h1
17 Oct 2017
Thanks mate fingers crossed, yes I passed VSE before this.
tips for VSE:
read instruction carefully, take your time when you practice the practice example for task 1 and task 2, task 3 there is no practice example but read instructions. don't panic, be relaxed and stay focused.
good luck.
Daly131
27 Feb 2017
Also @J05h1 what did u practice before the assessment centre for vse just the booklet they sent or did you find any online material that helped cheers
J05h1
17 Oct 2017
I watched a video on YouTube regarding VSE which helped me prepare also I read somewhere here on the forum about task 2 and task 3 which gave an idea of what to Expect. Just practice the practice example on the day I did it more than 10 times to get it clear in my head. Use Bop it it will help with reaction time. Just remember dont panic stay calm and focused.
Daly131
27 Feb 2017
That's good to hear!! Ive been trying to prepare in the same way.... few mixed theories about the VSE on here tho. I like the idea of bop to improve my reactions im ginna give that one a go, cheers buddy
izzyali
29 Nov 2016
Hi all,
Many thanks.
HI @J05h1 how did you get on with your DMI?
Also can you remember the type of questions they asked and and info about if it was similar to the MMI?
thanks
