trainJam
Luckily I haven't run into a major problem whilst using an area ticket yet, so this is mostly hypothetical but good to know.
The first scenario is about holding a combination of an area ticket (e.g. ranger, daytripper) and advance ticket when there is disruption when roaming around the area that the area ticket covers.
To give some specific examples:
- Advance single from Birmingham New Street to Liverpool Lime Street and another advance single to get home from Liverpool Lime Street to Birmingham New Street. With Mersey area ticket (this could be either the superior Saveaway or the northwirrallines day saver) to ride around the system all day, then catch the booked train home.
- Birmingham New Street using 2 advance singles and purchasing a Network Daytripper or West Midlands Day Ranger.
- Glasgow using 2 advance singles and purchasing a Strathclyde Roundabout.
Assume that at least the minimum connection time at the origin of the advance is left on the return.
1. Suppose, due to disruption whilst roaming (in this case on Merseyrail), I miss my booked train home. Would I still be protected (ie not have to pay a new fare) in the same way as if I were not using an area ticket?
2. How would I explain my circumstances to staff or inspectors to resolve this situation? I wouldn't be able to state a proper "origin" station.
3. Would I be entitled to compensation:
a. If the delay was on a National Rail (e.g. Merseyrail) operator?
b. If the delay was on another mode of transport (e.g. Bus, Ferry, Tram (WM))?
c. and similar to 2, what would I put as the origin?
4. If the area ticket is bought on a separate day to when the advance tickets were booked (e.g. on arrival into Liverpool/Birmingham) does this change anything?
A second, similar scenario is a day travelcard return from outside of London - in this case, the advance problem is removed so my main concern would be missing the last train of the day. For instance, suppose I have a Birmingham to London Zones 1-6 travelcard. Due to transport disruption, I am prevented from reaching my London terminal before the last train departs. Again, assume I planned to leave the minimum connection (although it might be harder to calculate in London). I usually do plan to arrive half to a whole hour prior.
5. Would I be protected in this case (or would I be stranded)?
6. Same as 2.
7. Same as 3, with the obvious example of Tube (including Elizabeth Line in core) for part b.
6. Same as 2.
