Popular in the mess room then? Do you drive?
There is no reward for arriving early, or even on time.
There is usually tea and busicuits for making an error.
You might dislike the current culture. The current culture would likely have meant people would still be walking around alive today that are not.
I don’t drive trains, no. However, I‘ve been in enough messrooms (how you measure popularity is an interesting question, but I think I get on with most people), and done countless cab rides, and know enough drivers, Driver Instructors and Driver Managers to know what good, and not so good, driving is like. It would be odd if every driver was brilliant, wouldn’t it?
From another perspective, when I managed signallers, I had some brilliant signallers (most of them), and some who frankly weren’t very good. I knew the brilliant ones would almost never have a delay or wrong route (and, coincidentally, their absence record was somewhat better than average). The less good ones had regular issues - “sorry Guv I was unavoidably distracted” (by reading the paper, for example, in more than one case), and often had long absence records with indeterminate reasons. This is the same in in all lines of work, in my experience - some people are simply better than others at their job.
There
is reward for arriving on time, albeit not for most train crew. Yet.
But, for the avoidance of doubt, I’m not talking abiut culture. Safety is the first priority. Running trains to time is the second. It is what our passengers want. What I am talking about is the very small minority of drivers who drive - sometimes - well below the linespeed (per this thread topic) or seem to only use step 1 braking and/or accelerate cautiously in good conditions and thus lose time. This is not only a performance issue, but it is also a
safety issue. Because following trains will unnecessarily recieve cautionary aspects, thus increasing SPAD risk. (I have personally investigated a SPAD where a contributory factor was that the signal was at danger for longer than it would have been normally due to a train travelling more slowly than noramlly ahead). Also it will cause distuption and potentially increase staion crowding risk.
I completely missed this joke - can you explain?
ATO!
Well, maybe. They won’t be going above 90 on the slows, so I assume you were on the fasts? I know they have a “passenger comfort” policy ir not taking full power below 10mph(?), but it seems a little odd that a driver would choose to drive 20 under the line speed, as it will only lead to more time in the chair, shorter breaks, a later finish etc.
I realise you know your onions, but are you absolutely sure there wasn’t a TSR, a unit with motors out etc.?
Definitely no TSR. Definitely no unit problem.
Yes on the fasts. Barely got above 80. Coasted from Grahame Park neutral, braked for West Hampsted South before Cricklewood (we had the Flashing Yellows, I could see them), and hit the 50 limit for the junction before West Hampsted North (for those that dont know, thats half a mile early). Under 40 through the junction. etc. Perhaps the worst of it all was braking so early for St P, that driver had to retake power to get to the stop marker.
There was probably a reason for this. Some sort of defect which required a maximum speed. Something isolated, or a broken window or something.
Reporting a driver for doing their job correctly
There may well have been a reason. But not a defect in the unit, infrastructure or signalling. Thats why I have reported the delay to investigate. I have
not reported the driver, although I hope he/she is asked for their version of events. I’ll have a tenner that the answer that comes back is that the driver can’t recall.
