Are passenger and freight "Buckeyes" the same?
USRailFan
2 May 2011
Norway
"Buckeye" couplers have been used on passenger trains in the UK since the 1930s, AFAIK, although for freight traffic they're a more modern phenomenon, mostly post-privatisation. BUT - are these 'buckeyes' the same? I've seen some suggestions that the passenger buckeyes are a lighter/weaker type, while the freight "Buckeyes" are identical to the standard North American "AAR" coupler?
Supercoss
5 Jun 2016
Two very different styles the modern " knuckle" coupler found o DB class 66s and 67 m swings away horizontally also known as a combination coupler , older locos like 33/1 and 73 and class 90 have drophead buckeye that lowers vertically (normally associated with 'rubbing plate for gangway stock and extendable/retractable buffers. The National Power class 59/2 also has drop head knuckle when new .
I once saw a non combination coupler loco sent to assist a freight train in rear only to find the last wagon had a knuckle coupler with no buffers.
Also throwing into the mix the Highspeed Train sets "Alliance" style coupler a fixed buckeye!
Dunfanaghy Rd
16 Sep 2019
Alton, Hants
I believe that the geometry of the mating face is the same. However, the swing-head coupler as fitted to 66's and 67's (and FCA and MBA wagons) unlocks by means of lifting the pin from above which is incompatible with the Pullman breastplate above most passenger couplers. I know that the swing-head works with fixed-head couplers (I once sent a Mendip Rail box attached behind a FCA). The presence (or not) of top shelves, bottom shelves, side pockets, &c. shouldn't affect the issue.
The Alliance is the one fitted to EMU's, isn't it? If so, it's the same as a buckeye but machined to finer tolerances (the AAR 'E' & 'F' are pretty agricultural).
Pat
43096
23 Nov 2015
Pat
Alliance couplers are those fitted to HSTs. Tightlock is the name usually given to the type on EMUs.
43096
23 Nov 2015
You can tell I was in freight, can't you :E So. in my post above, substitute Tightlock for Alliance. Simples!
Pat
:smile:
Presumably the finer tolerances you mention are the reason why Tightlock is used as the name?
Dunfanaghy Rd
16 Sep 2019
Alton, Hants
:smile:
I only encountered the Tightlock during my shunter's course in 1993. I know they had to be finished to finer tolerances to allow the electrickery to couple as well. That's as much as I can remember from that far back!
Pat
Tightlock as the name suggests with little 'tell tale' indicators that pop out when couplers locked correctly
here is a view from above of a class 319 tightlock
tightlock to buckeye can be coupled in emergency with adaptor bits kept on train
Is that the mushroom headed doofer? Intended to push the breastplate away, if memory serves (which it often doesn't).
Pat
Supercoss
5 Jun 2016
Yes that's it and a long screw thread bar that caters for height difference
USRailFan
2 May 2011
Norway
OK.
The reason I asked, was that in a Norwegian facebook group, it was claimed that UK Buckeye couplers used for freight, were identical to the standard US AAR type coupler, but that the 'Buckeye' couplers used on passenger stock was of a lighter/weaker type, and they couldn't be coupled to each other.
Dunfanaghy Rd
16 Sep 2019
Alton, Hants
I've just looked back into some TOPS notes I have. Among the 2 dozen codings for different combinations of couplers / couplings there are: Drop-head Buckeye, Fixed-head Buckeye, Alliance, Tightlock, & AAR 'E' & 'F'. The Buckeyes are for Loco-hauled carriages, aren't they? I have an idea (probably mistakenly) that they are an older US standard, probably one of the Master car Builders (MCB) 'D'. The AAR couplers are as currently used in the US. Operationally there is a difference; with AAR types you don't have to hang on to the lever for grim death until they part!
Pat
hurri67
25 Sep 2015
Pat
Are you sure about FCA’s with autocouplers? IIRC I thought they were all screw couplings.
I know the FAA’s were combination couplers.
WAO
10 Mar 2019
If you can download this file (Except you probably can't get it direct from RSSB)
RSSBsd001 Iss 2.pdf or the full document RIS-2790-RST Iss 1
You might try (No g'tee):
you'll be able to couple and wire anything into anything else in older rolling stock! It's (SD001 section) has 156 pages and couplers don't start until page 120.
WAO
Dunfanaghy Rd
16 Sep 2019
Alton, Hants
Aha, you spotted my deliberate error! :lol:
Stupid of me, you're quite right. Its worrying how quickly familiarity with wagons declines once you stop being involved. (Proves the value of periodic assessment and refreshing, I suppose.)
Pat
All RSSB standards are freely available on their website: Select the standards catalogue from the standards menu and you can search on just 2790 in this case. I've tried it and it works, but I suspect the link only works once so I won't put it here.
WAO
10 Mar 2019
It was just that one is asked to login or register (said to be free); some may not wish to do that. Hence the alternative.
WAO
WAO
You do get asked, but to access the standards catalogue you don't have to. Not so important for a forum discussion, but anyone using standards "for real" is better to go directly to the source to be sure they pick up the latest version.
