Are drivers trained on what to expect to feel from a derailment?
aar0
13 Sep 2016
Out of interest, are drivers trained on what to expect to feel from a derailment? Or it is just a case of “that feels wrong, I’ll stop safely and inspect”?
Northampton
I expect one issue with designing any training is that there are a range of ways derailments can happen and a variety of places they can happen which would result in very different feelings in the cab. If you trained for every eventuality you'd never pass anybody out and if you trained for only some eventualities, a driver might have a derailment but think 'oh that doesn't feel like what a derailment would' or something similar.
Acey
16 Nov 2018
Had no training but have had 3 derailments ( in yard 5 mph ) if at the driving end it's a bit hard to miss !
Didn't the driver at Potter's Bar only know something had happened because the brakes came on?
IIRC he felt a series of jolts, which was very shortly afterwards followed by the emergency brakes coming on. However he wasn’t aware it was a derailment until looking back along the train.
The report doesn’t actually say, but the fact that he looked back rather than commenced fault-finding on board the train suggests he had quickly formed the opinion something serious was wrong.
There was also a Railtrack manager in the cab who observed a signal briefly revert to danger, which may have been a factor. Again the report isn’t entirely clear, however it seems the driver didn’t notice this, presumably he might have been looking at cab indications to see if anything was indicated that could explain the jolts or brake application. All this would of course have happened within a couple of seconds.
king_walnut
16 Oct 2013
No. We're taught what to do if there is one but not really what it would feel like.
In the case of the Lewes derailment, the coaches came apart so that would have dumped the air pressure and applied the brakes. The driver would have known something major had happened but wouldn't have immediately known that 3 coaches were on their side at the back.
AverageJoe
23 Dec 2021
United Kingdom
If would probably be different for freight when driving on different routes, but for me as a passenger toc driver I know the tractions and routes like the back of my hand so I’m pretty sure I’d notice quickly.
Being upside down would also make me think something might have gone wrong too
Recessio
4 Aug 2019
There was a freight on the Gospel Oak-Barking line who managed to go more than two miles without noticing before the brake pipe separated and the brakes applied. It absolutely chewed up the track sleepers and cabling.
Summary
Shortly before 06:00 hrs on Thursday 23 January 2020, a wagon in the rear half of a heavily loaded freight train derailed on a small radius curve as it crossed a bridge in east London. The forces from the train caused the rails on the bridge, which were attached to large longitudinal timbers, to spread apart. Two adjacent wheelsets from different wagons derailed, but one wheelset re-railed itself after travelling a short distance. The other wheelset remained derailed as the train continued for 2.5 miles (4.1 km) before stopping, and this caused significant track damage. Wagons positioned behind the derailed wagons remained on the track.
trebor79
8 Mar 2018
The freight derailment at Ely went done distance too and ended up causing the route via Soham being closed for a long time as a bridge had to be rebuilt.
Harpo
21 Aug 2024
Newport
The Hatherley (near Cheltenham) freight derailment in October 2005 caused 4 miles of track damage. It had run over 60 miles with a wheelset that wasn’t rotating due to a handbrake being left on.
Recessio
4 Aug 2019
Can someone smarter than me tell me why this is at all possible? Surely some sort of basic sensor setup to check whether a wagon is still on the rails is possible.
Maybe it could check if the wagon isn't at an extreme or impossible angle, that the bogies are not at an extreme or impossible angle and that the wheels of the wagons are still turning and haven't become significantly slower (or faster I suppose) than other wagons in the consist. If one of these is true the driver is alerted (to avoid trains stopping constantly for false alarms) and if two of these are true the emergency brakes are applied.
I understand this would probably be rather expensive. But is there a technological or logistical reason why you couldn't implement something like that? Obviously not exactly what I have said as there's probably much better ways to figure out if a wagon is still on the rails.
I don't know about freight wagons, but don't passenger trains have wheel slip detection? Would that not detect that suddenly one coach's wheels are not doing what the others are doing?
