The original poster stated that the picture was over-exposed thus explaining the bright band on the head of the rail.
I have seen RCF of exactly this nature in the Americas before, where the top of the rail is well worn but with RCF marks on the gauge side of the rail.
I am trying to ,locate a picture with this type of RCF pattern.
It is particularly prevelant on heavy-haul freight railways and seems to be related to a particular strength of steel in that scenario. There are trials with a different steel ongoing to see if this is the case. Early experience suggests this is so.
The photo was taken in the US where the practice is to grind the whole running surface of the rail and the gauge corner, in order to restore the original profile of the rail. This grinding will go down into the RCF and remove it. The result is a clean rail head. A visit to the Loram website will find a video illustrating this.
In the picture there has been no reprofiling of the gauge corner which will allow the RCF to continue to propogate. That alone to me suggests no grinding.
This one has what appears to be the wear band with RCF still present and does suggest that it has not been ground. Tie this in with the original words and the wear band should not be as bright as it is.
If the original poster can supply a better exposed picture or can confirm the presence of any markings that suggests rail grinding HAS taken place, as asked by Trog then I am happy to look at it again and revise my comment. As far as I can see though, there is no obvious evidence of dust or contamination on the sleepers or the baseplates. That said, the US systems now do remove much of this during the grinding process.
If the photo has been taken in the UK then I would tend to go with Trog who is a very experienced Engineer and much respected by myself. Bearing in mind the fact that this is not in the UK I hold a different view. That does not suggest he is wrong, simply it is indicative of our different practices and experiences. I have never been involved in maintenance in the UK.
b0b
The reason for asking was to confirm that the head checking is due to the braking forces from the trains. Normally I would expect to see RCF primarily (but not always) predominantly on the outside rail where a curve is involved. In the US they do not apply cant in the vast majority of Railroads unlike European practice. The type of RCF in the photograph gave every indication of head checking through traction braking forces, and your reply supports the belief that this is the means by which it is propogated. I have a case of some 900 miles of track where this problem is evident but only through S&C
