What if the passenger wishes to continue, but the TOC cannot provide the means to do so? The view of many commentators appears to be that offering a refund and refusing further assistance (even where it is impossible to provide) is not an option.
I think we've discussed this one previously and I think we're both unlikely to change our positions! Suffice it to say, in this situation it was possible for the TOC to assist, as demonstrated by the fact that the OP managed to board their train.
I don’t think that is in any way contradicted by 28.2 which makes no mention of underlying contractual relationships.
This ultimately comes down to interpretation. I fail to see how 28.2 can have any meaning, unless it creates an enforceable right against other TOCs.
Simply because the obligation to assist (so far as reasonable) comes from NRCoT itself, which the TOC is a signatory to, rather than from the contract with the passenger.
It can't be an obligation unless there's a corresponding right to enforce it if the obligation is breached; the right to enforce it only arises if the other TOCs are party to the contract.
In addition, if the intention has been to create a binding contract between the passenger and all operators, this could have been expressly stated.
It could have been, but the failure to explicitly state things is a common feature throughout the NRCoT! I don't think that it can in any way be used to suggest the absence of a contractual relationship.
To put another way, just because you’ve entered into a contract with one operator that incorporates the NRCoT (and all operators are signatories to the NRCoT) it doesn’t follow that you’ve entered into a contract with all operators.
I find the notion that a passenger buying a ticket for a journey on a Thameslink train is entering into a contract with Scotrail to be fanciful in the extreme.
It's only really fanciful because ScotRail would never be likely to be reasonably able to assist. And so whilst that contractual right exists on paper, there are unlikely to be any circumstances in which it would be exercised. If you take Thameslink and LNER instead, it's no longer fanciful at all.
Isn’t that your viewpoint rather than a statement of the legal position?
Everything written on a forum like this is someone's viewpoint! I don't think any of us are Supreme Court justices
If the TOC chosen not to accept other tickets, and despite this you board with a ticket for a different TOC, you are still potentially committing a ticketing offence.
In some circumstances, yes - however, the fact that an offence may be committed doesn't mean it's the end of the story. Our putative defendant could apply to have the proceedings stayed on the basis that they're an abuse of process, if the offence only arose as a result of the prosecutor breaching their obligation to assist the passenger!
In practical terms the key thing, in the absence of certain knowledge ticket acceptance is in place, is always to ask permission first.
That's usually a good point to start from. However, in the situation the OP was in - being at a station where there are no WMT staff present - it's unlikely that this would have got them very far, as the staff would likely have told them that they need to buy a new ticket to travel on Avanti.
If you ask for permission but it's wrongly denied, it's difficult to suggest that you should shell out huge amounts to make up for the failings of TOCs.
So if turn up at the airport and Ryanair has cancelled your flight, you’d expect BA to take you even though you hadn’t bought a BA ticket?! Good luck with that.
I think it is well established that analogies with other industries don't really work very well! But if we must, the closest airline analogy would be if you had a booking for a flight legally operated by Ryanair's UK division, Ryanair UK Ltd (as opposed to Ryanair DAC, the main Irish entity) and the Ryanair DAC staff at the airport refused to rebook you on alternative flight, telling you to try and find someone from Ryanair UK to help.
They may be technically correct from an EU261 perspective, but they would be wrong from a contractual perspective - where there is no distinction between the DAC and UK Ltd. Just as in the rail example, Avanti would be technically correct to refuse assistance under the PRO, but still have to do so under the NRCoT.
