thebigcheese
- Joined
- 2 Jan 2012
- Messages
- 165
I posted a while back about an issue I was having with ticket excesses on South Eastern and had a similar problem recently. The reply from SET (quoted below) does summarise this issue quite well.
My travel was using this ticket which is £55.20. On the return portion only I wanted to excess to this ticket which is £59.40. I understand this should be half the cost so £2.10. Instead I was sold a high speed upgrade for £4.20 and had to complete the underground journey at my own cost.
Incidentally the clark at Gravesend was able to find the info in 'the manual' after prompting but as there were no instructions he couldn't do the excess and wrote the following on the back of the ticket:
My query is over SET's assertion that the excess should be based on the cost of single tickets rather than half the difference of the tickets I was using.
Firstly I'm sorry that you have had to take the time to write to us, I'm also disappointed to hear that despite making the same complaint a year ago the issue has occurred again.
I understand that you were traveling between Southampton and Gravesend and on your return journey you wanted to change the routing of your ticket, to travel via London St Pancras on the high speed service and then travel via the underground to get to London Waterloo. I can also see that you attempted to purchase an excess fare from the ticket office at Gravesend however the ticket office clerk was unable to process your request, it appears that you then got on to the High Speed service to London St Pancras and attempted to purchase the excess fare from the conductor, however you were sold a single high speed upgrade, which is what youre requesting a refund on.
As you have already used one portion of your ticket to make your outbound, you would have been eligible to pay an excess fare for a single ticket rather than your full return ticket. The ticket that you would have required to travel via your intended route would have been an Off-Peak Day Single Plus High Speed at the cost of £51.60, what you were effectively traveling with for the purposes of working out the excess fare, was an Off-Peak Day Single London Not Via Underground ticket (Not Valid for High Speed) and the difference between these two fares and what you should have paid as an excess would have been £4.20, so for this reason it seems that you have been overcharged.
Once again I apologise for any inconvenience or confusion that may have been caused by this, I hope that this explanation is useful. I hope that your future travel is without difficulty. If you have any questions, please do not hesitate to contact us.
