Another Oyster Query
mercator
9 Aug 2010
This is my first post! One Saturday I will be checking out the London Overground and would like to use Oyster pay-as-you-go. As I will be inside the gateline for most of the time I had assumed that I could touch out and then immediately back in again to break the journey to avoid exceeding maximum journey times. However from what I hear this will not necessarily end one journey and start a new one. What time do you need to remain touched out before touching back in to create a new journey?
Also if the daily cap is reached are additional charges for exceeding the maximum journey time still added on top of the daily cap?
I expect the advice will be to use a Travelcard instead of Oyster but it would be useful to know these answers. Plus it might be a challenge using Oyster!
RJ
25 Jun 2005
Back office
Buying a Travelcard would be very good advice. You can touch out/in straight away if you validate on gateline barriers. If on a freestanding validator however you will have to wait five minutes (this prevents passengers being overcharged for accidental duplicate touches).
Once you reach the daily cap, you must continue to touch in/out correctly otherwise you just get charged even more. Oyster works by automatically deducting an Entry Charge whenever it is touched in. The appropriate refund is given when touched out correctly. The Entry Charge still gets deducted when the cap has been reached, but that amount is fully refunded when touched out again.
AFAIK the cap is completely disabled for the day if there has been an unresolved journey undertaken.
MikeWh
15 Jun 2010
Crayford
What RJ says.
The other issue with touching out and in again refers to using different but nearby stations (or sometimes different parts of a large station). These are usually programmed as out of station interchanges and will continue a journey as long as the touches are within a set timeframe. Typically 15-20 minutes but can be up to 40 minutes at NR termini where you might wait on a concourse. There's a full list on my website (link below my posts).
If roving around for a long time I really would recommend the paper travelcard option though or you'll easily fall foul of maximum journey times.
