Another bridge strike at Purley!?
Islineclear3_1
24 Apr 2014
PTSO or platform depending on the weather
My daughter is currently at London Victoria trying to get to Gatwick and Southern are showing delays or cancellations "due to another vehicle striking a bridge in the Purley area"
What is her best course of action? A message on the boards at Victoria is advising passengers to board alternative Southern services - however, if they can't get past Purley, how else is she going to get to Gatwick?
Northampton
From Traksy/OTT trains (EDIT) may be passing through Purley on the Slow Lines.
The bridge immediately south of Purley has 2 separate structures - 1 for the Fast Lines (Platforms 1-2) and 1 carrying the Slow & Cat/Tat lines (Platforms 3-6). 1R35 has been in the signal section for a few minutes so is presumably examining.
Northampton
Thanks. I told her to try for 1H36 which she managed to get. Fingers crossed...
Yes, looks like the Down Slow is passable (possibly at reduced speed), 1H36 has the route for departure from East Croydon to the Reversible Slow, so she should get through, albeit slowly as the trains will be signal to signal.
Actually, looking again the bridge immediately south of Purley looks very high and doesn't have a restriction on it: https://maps.app.goo.gl/v3dcyLErgrV59ThK9. Trains are also not weaving back at Purley Jn so I think it might actually be one of the bridges north of Purley, some of which are 1 structure and some of which are several structures immediately alongside each other.
Either way, it looks like all trains are being run via the Slow lines between East Croydon and Purley, so there will be delays and cancellations to manage the restriction on capacity.
Mcr Warrior
8 Jan 2009
@Islineclear3_1. What time does/did your daughter need to arrive at Gatwick Airport by? Looks like the train she's on (the 1446 from London Victoria to Littlehampton) is approaching Purley just a few minutes down, next scheduled stop being Gatwick Airport!
Islineclear3_1
24 Apr 2014
I'm following the train on OTT. She needs to check in 4-4.30. I told her to get the train early... thankfully she took her dad's advice...
Mcr Warrior
8 Jan 2009
Train looks to have arrived at Gatwick Airport some 22 minutes down at 15:41, so should now be eligible for some 'Delay Repay'!
