Anglo-Scottish services - Easter 2026
8 Mar 2015
Home Counties
Hello - not sure if this belongs here or under Fares advice etc.
I have, inadvertently, left myself needing to get from Glasgow to London on Easter Saturday next year.
I'm aware there is often major engineering work over the Easter weekend, and that next year's plans have not yet been announced.
Questions - when do Easter engineering works normally get announced, and is it reasonable to expect that one of the routes WCML/ECML will be remain open if the other is closed?
Thanks
8 Mar 2015
Home Counties
Doing a little more research... Caledonian Sleeper service from Glasgow on Good Friday is leaving earlier than normal to go via Edinburgh, so presumably ECML.. presumably that's because the WCML is closed south of MKC - but it does suggest the ECML will be open?
30907
One or other route should always be open. Policy after a c***-up a few years back.
27 May 2021
Daventry
Will the Northbound Highlander on Good Friday go WCML ie get through before the possession kicks in? Or is it booked ECML?
Looking to be on it to either Aviemore or Aberdeen depending on circumstances...
50039
8 Mar 2015
Home Counties
CS website shows it leaving 45 minutes earlier than normal on Good Friday... suggests to me it will go ECML.
I went Lowlander earlier this year, left early and went ECML.
A S Leib
9 Sep 2018
In January this year King's Cross – Peterborough and Rugby – Stafford were closed at the same time; would that try to be avoided, even with services being diverted through the West Midlands?
30907
No (evidently!) - a diversion via WM (or indeed Manchester) seems to be allowable. Academic for the OP though.
