and connecting services
JBuchananGB
30 Jan 2017
Southport
Hello
My sister has an advance single ticket Billericay to Cheltenham Spa, for the specific train departing Paddington on 15 May at 19.15. It is valid on necessary connecting services, including London Underground
It is her plan to depart Billericay 09.57, spend the day in the vicinity of Liverpool Street, then resume her journey from there to Paddington to catch that train.
I understand that advance singles are not generally valid for break of journey. Is this ticket valid for her plan?
Hello
You are correct, it's not valid. Break of journey is not permitted on Advance fares, and taking a train that is many hours earlier than an appropriate connecting train is likely to be frowned upon.
The fact BoJ is not permitted should have been made clear at the time of purchase. Where was the ticket purchased?
JBuchananGB
30 Jan 2017
Southport
I don't know where she purchased it. Probably online at the Great Western web site.
She has been making weekly trips on Tuesdays Cheltenham Spa to London and back for over a year using Advance tickets, but on this occasion she is coming out to visit Billericay on Monday instead of catching the 07.30 from Cheltenham on the Tuesday.
At what point on the journey from Billericay to Liverpool Street is the ticket likely to be frowned on. Would it fail to operate the gate at Billericay or at Liverpool Street?
tsr
15 Nov 2011
Between the parallel lines
It's impossible to say, really; the automated analysis of paper tickets at gatelines isn't terribly clever and generally wouldn't be able to reliably accept or reject tickets for a complex, timed journey of that nature; if the barriers don't open, you'd be relying on the goodwill of any gateline or onboard staff who saw that the ticket was an Advance one, and decided to ask for the reservation coupon. They're more likely to be filtering by locations, ticket type (Advance/varieties of walk-up) and discounts (child/Railcard) - and of course the date of travel. Therefore the ticket could still be rejected even if it was valid for the time of day, if it was discounted or of a certain type. If the correct time is stuck to, and it's then passed by a manual inspection, that's fine. However, the same ticket could equally be rejected by the barriers at the wrong time of day as well, and then an inspection could result in travel being denied, or worse.
I suggest that a manual check of the reservation coupon is more likely to occur when entering a mainline station, or onboard mainline services, but you can never be sure.
Pausing your journey within the station itself for half an hour to an hour would be perfectly reasonable - for example, if you've just travelled in good time for your booked leg of the journey, and want to get some food on the way - but it may be a problem when it extends much further than this, or if the passenger leaves the rail network, in this case including a route across London.
Often, cross-London journeys can be difficult to track for revenue staff, as there are often several different, valid routes across London for each ticket, or they may take significantly different amounts of time, or they may involve crossing roads or busy concourses between Tube and mainline stations. For example, some journeys may be much longer than others if you're limited to the sub-surface lines (eg. Circle/District) because you've got a non-folding bike. However, this is no excuse for breaking your journey for several hours halfway across town, and questions might still be asked.
In other words: break of journey (leaving the network/stations en-route) is not permitted, and whilst you may get away with it around London or on the Tube part, railway staff often have their ways of spotting things which are wrong, and it could quickly get you into trouble.
(...by "you" I mean a passenger...)
robbeech
11 Nov 2015
If they are prepared to pay for a £13 anytime day single if they say no then it has to be worth going to ask staff at the station with a little extra time before the 0957 departs. It is NOT valid officially as others have said, but the guard may allow it at his or her discretion. If you wait until you ask the guard and they say no, and they also will not sell you an anytime day single on board you'd have to buy one from the ticket office and would likely miss the 0957, though the service is fairly frequent, the next being 1017.
There is no Guard, OBM TTI, so it depends on whether or not revenue staff board.
