Altrincham to Hale... via Stockport?
gnolife
4 Nov 2010
Johnstone
Good afternoon all.
I've just had a look on BRfares for the cost of a Altrincham to Hale ticket, and found that they are all routed via Stockport. Does the route restriction take priority, and I have to travel via Stockport, or does the rule prohibiting doubling back take priority, and I have to travel on a direct service between the two, or do I have to consider both, and travel via Chester?
I admit that the first and epecially the third possibility are decidedly unlikely, but I thought I'd ask anyway.
You are permitted to travel via Stockport.
The direct route is, however, a protected route and covered by through trains, so they cannot force you to travel via Stockport.
There are no mapped routes between Altrincham & Hale, so none of the rules regarding determining mapped routes apply.
You are permitted to travel on a through train between Hale & Altrincham
via Chester wouldn't be permitted. See 3.6 Tickets routed via stations that are not on a permitted route
brompton rail
28 Oct 2009
Doncaster
I don't understand! Why would you travel via Stockport to go from Altrincham to Hale. It is the next stop and three minutes away.
It's a mistake. It allows cheap travel to/from Stockport until it's fixed though, which probably won't be long now the anomaly has been exposed.
