Alternative Destinations for MML Trains in London
Topological
20 Feb 2023
Swansea
Seeing the discussion about the limitations placed upon the Midland Mainline (MML) in London by the lack of platform capacity at St Pancras, are there other destinations that trains could run to instead? (I am thinking more of the Corby EMUs rather than the longer distance stock)
From the WCML there is the option to run through to Clapham Junction via Kensington Olympia (for example), but are there any sensible destinations that could create connectivity for the MML?
Appreciably Thameslink trains go into the core, but presumably this would be too much for the Corby terminators to be added to Thameslink.
If 4 platforms at St Pancras only needed to handle 4 trains per hour from the MML longer distance services then there would be more options open to East Midlands Railway when reaching London.
So is there somewhere for the Corby trains to go to instead?
Helvellyn
28 Aug 2009
Short answer is no.
King's Cross is keeping some Great Northern/Thameslink services that should have gone into the core as Thameslink (which is why some Thameslink services terminate at Blackfriars still as well).
You would also have longer journey times if you tried diverting the Corby services elsewhere.
I'm not really sure what the issue with MML services is though. The Corby Service is timed to effectively have exclusive use of Platform 1 at St Pancras, which is two trains per hour. The remaining four trains per hour have three platforms to use.
With a bit of extra electrification they could wander off eastwards on the North London Line or towards Barking, getting in the way of the Overground, but there's not really any point. Even if there was a way of terminating more MML trains in London, there's no capacity to run any more on the route shared with Thameslink.
The specific issue discussed in the other thread concerns two track railway on Sunday mornings.
St Pancras has ample space to turn round six trains an hour in four platforms. There are concerns about passenger space, but with all the long distance services running with 810s it should be straightforward to manage turnarounds sensibly within the available capacity.
If another destination is needed, the middle platforms at Kentish Town aren't heavily used.
Topological
20 Feb 2023
Swansea
Short answer is no.
I agree that on paper there should not be any issue.
However, whenever there is a discussion of running longer trains on the MML (e.g. 10 car 810s) the answer is always that they need to share platforms at St Pancras. As an outsider it would seem 3 platforms for 4 trains per hour would work, but...
Hence looking if there was anything that could create a 4th platform without any major issues.
Not suggesting a need for more trains on the route shared with Thameslink, just making it possible to have longer trains on the MML again.
Nottingham59
10 Dec 2019
No. But Thameslink could provide a service with 700s to Kettering and Corby using the EMR paths. If they ever get throughput up to the 24tph that was promised for the Thameslink core.
Starmill
18 May 2012
Bolton
In reality it's not difficult to turn around four services per hour without sharing at all. The only real issue is how punctually trains can arrive and how long of a turnaround time there is available at the other end of the route. Speeding up cleaning isn't really that difficult as it's already done quite fast.
The myth that St Pancras is short of platforms is like a whack-a-mole; it keeps popping back up.
1) it has plenty of capacity for the EMR services that use it in normal running.
2) when the 810s arrive, it gets easier, even wiht 10 cars
3) There is no capacity on the MML south of Leicester for more London EMR services anyway, at least not without removing Thameslink services and doign one of i) removing frieght ii) extending journey times for Sheffield / Nottingham services or iii) taking out some calls south of Leicester from some existing EMR London services.
cle
17 Nov 2010
The glib answer here is EWR - a Corby could take a Bedford-Oxford frequency once that goes live. And maybe allow another slower service, often mentioned as a Leicetser EMU (might time up with that fifth platform... inshallah...)
TL - I could see the odd Wellingboro' extension - plenty of capacity on those slow slows now quadded. Beyond that, journey is getting far too long for the current stock allocation.
Or a situation where Nottingham had an hourly KX, and dropped to hourly MML. Funnily enough, similar (but OA) was suggested for Sheffield.
Finally, if HS2 could get up toward Burton, that might also be able to free up another thing.
But these don't quite answer the question of an alt terminus - Kentish Town is the boring, most likely answer - maybe with a West Hampstead call also (could the Corby-s do that)- plenty of connectivity.
stevieinselby
6 Jan 2013
Selby
The only realistic alternative to EMR running Corby to St Pancras would be to extend every other Bedford TL train to Corby.
It's half an hour each way, so you would need an extra two 700s in the rota.
And then you have to extend the platforms at those stations to 12-car length.
And passengers from Corby and Wellingborough have a slower and less comfortable journey, albeit potentially more convenient if the increased range of destinations helps them.
But potentially capacity issues – I don't know how busy the Thameslink Flyers are and whether they could accommodate the extra passengers.
About 600 people standing on each one in the peaks between St Pancras and St Albans.
Vexed
12 Jan 2020
Herts / Hants
This is stretching my memory but can I just check the Thameslink Flyers are the extra peak services that go straight onto the fast lines at Bedford, skipping some of the normal stops?
Starmill
18 May 2012
Bolton
I think you're thinking of what was running before the 2tph Corby services started.
Halish Railway
26 Apr 2017
West Yorkshire / Birmingham
I don’t think there’s much of a need for more frequent trains from St Pancras to the East Midlands, more a need for longer trains all throughout the day.
If there were to be any new destinations they should be extensions of the existing Nottingham and Sheffield services to provide better northbound connectivity from the East Midlands.
Cambridge for instance has never made *any* sense.
Cambridge to Brighton, offering a direct link to Gatwick Airport is, by all accounts, a successful extension of Thameslink. Kings Cross doesn't have the platform space for 12-car semi-fast trains to serve Stevenage and the stations to Cambridge.
If the argument was that Corby trains need to go to Thameslink to free up platforms at St Pancras, running semi-fast services from Cambridge into Kings Cross would be moving the problem next door.
How are you drawing the conclusion that running Thameslink to Cambridge has never made *any* sense? It can very easily be said that running Thameslink to Corby could never make any sense.
Hadders
27 Apr 2011
Running Cambridge to Brighton makes a huge amount of sense.
Direct service to Gatwick Airport
Conections to the Elizabeth Line (and Heathrow) via a simple single change at Farringdon
Simpler journeys to the City from places like Royston, Hitchin and Stevenage
Judging by the number of people boarding southbound Thameslink services (or alighting northbound) at Finsbury Park the services provide good connections from the Hertford Loop into the core (I know family members living in Enfield regularly make use of this connection). Before TL services went through the core no-one ever got on a Finsbury Park going southbound or got off travelling northbound.
the TL ‘express’ servcies still run, but not advertised as ‘express’.
Helvellyn
28 Aug 2009
Anything slows down Corby to St Pancras services, whether extra stops or a change of London terminal will do several things:
  • Drive more Kettering-London passengers onto the Nottinghams, which are non-stop to/from St Pancras.
  • Potentially encourage Corby passengers to change at Kettering for London if a quicker journey is available.
  • Encourage Wellingborough passengers to drive to other railhead (e.g. Northampton) where the fares are cheaper. West of Wellingborough anecdotal evidence people do that and if you live toward the East with easy access to the A6 Bedford is just as good an option (and fares are substantially lower).
Next year the 360s are being refurbished with 2+2 seating and more luggage space to more match the new 810s. So they are a key component of the EMR service offering.
Magdalia
1 Jan 2022
The Fens
Or by removing something else from Thameslink and simplifying its operation as a result. Cambridge for instance has never made *any* sense.
Cambridge-Brighton is by far the most sensible Thameslink addition associated with the Canal Tunnel. Most of my southwards journeys from the Fens are on the Brighton service. In addition to the above Thameslink offers good connections at London Bridge and East Croydon to most of Surrey, Sussex and Kent.
The route that was moved onto Thameslink that makes far less sense is Peterborough, and it is a warning of what would happen if Corby was incorporated into Thameslink. Many discussions here document the difficulties with the Peterborough service and the knock on impact, particularly for the Redhill loop. There is a distance from London limit for Thameslink beyond which lack of resilience gets too big. That appears to be about 50-60 miles, for example Brighton, Bedford and Cambridge. Furthermore, too much mixing of long distance "Inter City" operations with Thameslink is bad for the resilience of both.
Thameslink has already dropped through running to Littlehampton, another long distance route. My preference would be for a way to be found to get Peterborough off Thameslink too, and it is definitely not a good idea to add Corby. Thameslink needs to be made more simple, not more complicated.
Simple in resilience terms is to connect as few lines as possible. Thus, connecting ONLY the MML and Brighton Mainline is the best approach (give or take the Sutton loop). It should never have gone beyond that, not to Cambridge, not to Peterborough, not to Littlehampton, none of them. Corby is still MML. If we wanted to take Cambridge services across London to somewhere else, it should have been on a totally separate, new "Thameslink 2" line.
The key is not connecting multiple lines, because that way you get cross-pollination of delays and you can't easily swap destinations of a delayed train. That has destroyed any punctuality it had.
Compare Merseyrail and Castlefield and note why one of them is (broken 777s aside) considerably more punctual than the other.
That is more about saving costs than it being a bad idea to have a few peak trains through from London Bridge to Littlehampton. The Southern peak services from London Bridge to Bognor Regis and Eastbourne have been withdrawn as well.
TBH Littlehampton is less of an issue than Cambridge/Peterborough because it's still a line off the BML-ish so there's less cross-pollination, just as Corby is off the MML. But I'd prefer to follow S-Bahn logic and *keep it really simple* - frequent, capacious, one or at most two destinations at each end. More like the Lizzie than what was attempted.
I suspect the idea of using Thameslink for these services was so they could be operated DOO instead of requiring OBS.
