Alexandra Palace Contactless Readers Disabled
trainbow
14 May 2019
I travelled via Thameslink/Great Northern to Alexandra Palace today for the fireworks, and upon arrival, all contactless/oyster readers were disabled and covered up.
A member of GTR staff was shouting something through the platform PA about TfL, but it was unintelligible.
Do they expect the thousands of people travelling through the station to contact TfL tomorrow to fill in their two journeys through the station? Or is there some other arrangement in place?
infobleep
27 Feb 2011
When there are large crowds, they auto complete journeys on a best guess.
Someone else will be able to give more information on this
island
30 Dec 2010
Indeed, when there is a major event near a certain station, for crowd control reasons they will occasionally set the system up so that all unfinished/unstarted journeys get autocompleted to/from that station in a batch process. Give it a few days to settle down. If there's still no change, then go online or call.
paninaro
26 Dec 2022
Presumably you'd need to start the return leg at that station (Alexandra Palace in this case) so the system would know you'd gone to the event? Or would literally any unfinished journey in London at that time get autocompleted to Alexandra Palace?
Dstock7080
17 Feb 2010
West London
Auto-complete was activated 1600-0030 for Alexandra Palace and Wood Green stations
greatkingrat
20 Jan 2011
For many stations the fare to Alexandra Palace will be different to the fare to Wood Green. Do they pick whichever is cheaper?
Haywain
3 Feb 2013
Wouldn’t it be based on the most likely route or journey to have been taken based on where the card was touched in?
greatkingrat
20 Jan 2011
If you are starting from the north, e.g. New Barnet or Arnos Grove, then it might be obvious which station you are exiting at. But anyone coming from the South will pass through Finsbury Park and could plausibly take either route.
island
30 Dec 2010
And if the wrong completion station is chosen you can go online or call to get back the extra few pence.
Haywain
3 Feb 2013
They could, but I expect that TfL will have a good idea of what is more likely.For instance, if you touched in at Moorgate, are you likely to have changed from National Rail to underground? And if you touched i at Leicester Square are you likely to have made the opposite switch? Some people will change but they will know about normal travel patterns and base it on that.
But the contactless system is advertised as will always be charged correct fare, if TfL have to guess and get it wrong, then might be better to complain to Advertising Standards Authority than oyster helpline.
Its not good practice to overcharge a customer and make it their job to sort out the problem, that's one that should be for the oyster staff to sift manually and sort out without customer being asked to intervene, after all it was their employers idea to create the extra work
Taunton
1 Aug 2013
What a complete waste of your time, acting as a surrogate accountant for TfL, constantly pawing through your journey history and identifying (if you can) errors, cross-referencing them with your calendar. I know the group here is an outlier, but most contactless users will not even realise. I wonder what limited percentage of those affected actually do this.
I remember asking around our office about this, most people didn't even understand what I was talking about. What if I tap in, and much later tap out, at Canary Wharf. Nothing else. How is it known I went to Alexandra Palace and back, and not some comparable contactless-closed place elsewhere.
Taunton
1 Aug 2013
Presumably they do this only for one location at a time.
Well what if I went to Crossharbour DLR instead, where the standalone in/out reader has a long history of being intermittently out of order?
Haywain
3 Feb 2013
The alternative would be to charge you for two incomplete journeys. Would you prefer that?
paninaro
26 Dec 2022
Arguably that would be clearer for someone who hadn't been to Alexandra Palace. They'd be a large fare (2 in fact) which they'd be more likely to notice.
Haywain
3 Feb 2013
Maybe, but the criticism is that they have to check that they have been charged correctly. If that's the case isn't it better to have a low incorrect charge that has a reasonable prospect of being correct?
MikeWh
15 Jun 2010
Crayford
Were they out of use after the fireworks?
Usually the arriving touch is foregone so as to avoid queues building up on the platforms and creating a dangerous situation. Returning after the event the queues are obviously outside so they expect you to touch in. That triggers the auto complete of the previous unfinished journey.
Surreytraveller
21 Oct 2009
This does make a mockery of the 'You must always tap in and out' mantra
What if someone cannot tap in and gets stopped by a RPI?
Hadders
27 Apr 2011
Touching-in is unaffected.
Hadders
27 Apr 2011
The OP stated that the readers were all covered up and disabled
The ones the OP passed were covered up but that doesn't mean all the readers were covered up. I would imagine that the card readers at the bottom of the stairs were covered up, with arriving passengers being directed to exit via the exit gates on the footbridge that are opened during large scale events. Departing passengers enter the station via the foyer where they can touch in as normal.
jon81uk
17 Aug 2022
Harlow, Essex
One assumes the large-scale events plan has a contingency in place that even if you do somehow get a check on the card mid-journey which doesn't get resolved by tapping out as the gates are open and readers off to exit due to the large volume of people, then when it is resolved by tapping in for the return journey it will all be OK.
If they didn't do this at large events you would have the risk of trains not being able to stop if the platform can't clear quick enough, or people with true unresolved journeys as they rushed when tapping out and didn't actually tap.
TfL have done this at many large events for years and there is information on the website about it.
Automatic completion of journeys​
When there are major sporting or entertainment events, we may open gates at stations to help with congestion.
On these occasions you might not be able to touch out, so we'll try to complete your journey for you so you're not charged the maximum fare.
If you're due a refund when we automatically complete a journey, it'll be loaded on to your Oyster card when you next touch in on a yellow card reader. If you used contactless (card or device) we'll refund your bank account.
trainbow
14 May 2019
On re-entering the station after the event, staff were standing in front of the readers stopping people from using tapping in.
In the end, they autocompleted my journey, but incorrectly due to tap in and out at Blackfriars to grab a coffee from Costa - they assumed I had returned to my origin. Used the online form to correct the record, and it was rectified a few days later with refund issued.
Hadders
27 Apr 2011
As I understand it the readers are not supposed to be out of use at the start of the return because passengers would be queueing outside the station. I'll bow to @MikeWh much greater knowledge int his area.
MikeWh
15 Jun 2010
Crayford
Indeed they should be operational for the return. I wonder if this is yet another case of GTR not wanting to understand PAYG.
