Air-con on trains
Thebaz
24 Nov 2016
Purley
I've always wondered who/what is responsible for switching on air-con on trains, as it often seems to be the opposite of what it needs to be. As I type I'm on a sweltering 377 12-car train that originated in East Grinstead. Suddenly the air-con pings on at ECR. Did the driver do it on a whim? Is he/she under instruction about when to use it to save energy (money) Or is it on a timer? Also it seems that as soon as there is a hint of Autumn in the air barely does Southern miss an opportunity to whack the heating up to the max, when often on commuter trains the combined bodily warmth emanating from the passengers would be enough to provide adequate heating.
Any answers welcomed!
I can't speak to 377s specifically but it's often something which is pre-set in depot and can't be changed by train crew. I believe, usually, such systems are designed to maintain the interior at a specific temperature (or at least try to) rather than just being set to hot or cold. So it could well be that at ECR the temperature in your carriage finally reached the point at which the air-con turns on to cool things down.
That being said on some units train crew do have more of an influence. I was once on a VTWC Voyager from Euston and the carriage I was in was absolutely baking with the HVAC pumping out heat on a warm summers day. Upon entering the carriage the Train Manager looked incredibly confused by the heat, strode down the carriage to the vestibule, fiddled with something and a few moments later glorious cool air poured out of the ceiling vents and the heat stopped.
FOH
17 Oct 2013
I was wondering something similar. Over the last few weeks the 377s have been an icy pleasure then yesterday morning, when the outside temperature was more normal, a sweltering zone of sweat.
physics34
1 Dec 2013
Driver has no control other than going into the cupboard of that specific coach and switching it off.
Each coach is thermostatically controlled. If one coach is too hot then maybe another will be okay. There is a range at which the air con is virtually off.. it tends to be when the temperature is very stable. The air con will only come on with any real gusto when the temperature rises to a certain level. (Or falls ..then the heating will come on). .. so yes, at average temperatures it can seem stuffy.
aleggatta
28 Sep 2015
377s are completely autonomous, whether there are any faults, well that's another issue...
Thebaz
24 Nov 2016
Purley
Yes, stuffy is the word! So if the individual coaches are thermostatically controlled to only react when it becomes uncomfortably warm for the passengers, that is a poor design. I have also been on some very warm 455s at the wrong time of year. By comparison class 700s seem to always have air-con operating.
Air-con appears to be one of those pernickety things that consistently breaks (see also: train toilets), and judging by what happened to my car, not cheap to fix.
Hadders
27 Apr 2011
In GTR land I find the air con on the 387s is generally poor. It is good on the 700s but the windows on the 365s never fail :D
chris11256
27 Dec 2012
I find c2c's 387s aren't bad. Although they seem to let it get quite hot/warm before the air con comes on. Not quite as good as 357s as they're normally like walking into a fridge.
I also find the S Stock on the district line can be rather hit and miss. Sometimes it's really good, others it's barely noticeable.
samuelmorris
18 Jul 2013
Brentwood, Essex
The S stock I find a little variable but that's to be expected given how often the doors are open. Generally it's fit for purpose, very rarely do I find a unit where it isn't working. 378s when it's really hot out seem to operate at a very low set temperature like 18°C, you can very quickly feel cold. Hitachi units like the 800s and 395s seem the opposite, the A/C does work but it's set to be pretty weak, say 25 or 26 degrees. I don't ever recall being on a 395 where it was cold, at any time of year.
aar0
13 Sep 2016
I've found the 800s to be freezing, I've been on one today and had to put a jumper on for the first time in over a month!
47271
28 Apr 2015
I've covered a huge mileage by rail during the heatwave: mainly Transpennine, Virgin, SWR and Scotrail. Apart from one Scotrail 170 that was well on the muggy side, temperature control has been good on trains with aircon.
As a further credit to modern stock, I had a hellish journey from Waterloo to Woking due to disruption the week before last on an unbelievably crowded Desiro. Insane numbers of people on board and 30C outside, but the unit still managed to keep us all cool.
samuelmorris
18 Jul 2013
Brentwood, Essex
In fairness I only have a sample size of 1 for the 800, but since it's the same manufacturer, same ventilation system by the sounds of it as the 395s which I have a lot of experience with, I kind of extrapolated there.
Cesarcollie said:
The Renatus 321s seem pretty good, even these last few very hot weeks...
I'd agree with that, when it works of course. They seem to have compensated for the slow reboot time and lack of climate-sensitive door control by running the system aggressively, so on a long inter-station gap they get pretty damn cold inside. From what I can tell, however, the system still fails regularly, with no emergency window to open.
physics34
1 Dec 2013
i assume the settings are adjustable. it prevents the air con from continually running then turning off and coming back on again then turning off and so on and so on...
aar0
13 Sep 2016
In my experience of probably 50 800 journeys I've never found myself warm, normally shirt buttons are done up, a jumper is added or a coat goes back on!
444/450 aircon I've also always found to be pretty powerful and reliable
Mordac
5 Mar 2016
Are LNWR turning the aircon down to save money? Desiro aircon is normally ridiculously powerful, but it's never felt cool enough in the 350s I've ridden during the heatwave...
