Belperpete
- Joined
- 17 Aug 2018
- Messages
- 3,586
A recent thread highlighted that there are various features built into the Oyster card system designed to catch fraudulent use, but which can sometimes unwittingly catch out legitimate users. In the case in question, the user made what he considered to be two quite separate journeys with a short break between, but which Oyster considered to be one linked journey. As he exceeded the maximum journey time for what Oyster considered to be one journey, so Oyster imposed a penalty fare. I have had a penalty fare in a similar situation, and also when exiting a station when finding there were no trains to my destination, and so tapping out too soon after tapping in.
These kind of penalty fares can cause a problem if you don't have sufficient balance in your Oyster account, and it therefore goes into debit without you knowing. In the thread mentioned, the OP did not have sufficient balance, and the situation then escalated for reasons irrelevant to this discussion. Fortunately, in my cases, they did not cause an issue, other than needing a quick phone call to get the penalty removed.
Am I correct in thinking that the issues caused by going into negative balance can be avoided by having auto top-up set to ensure that you always have sufficient balance? And if so, what top up balance would it be necessary to set?
Can this kind of thing also happen with contactless? Or is it only Oyster?
