Advances through London during the tube strike
cactustwirly
10 Apr 2013
I've got an Advance ticket from Leeds to Twyford via London on Thursday. In the event of a tube strike will I be able to travel on the 205 bus from Kings X to Paddington?
Nym
2 Mar 2007
Somewhere, not in London
I'd expect that ticket acceptance will be in place, weather you can actually get on the bus or not on the other hand...
Hadders
27 Apr 2011
I've got an Advanced ticket from Leeds to Twyford via London on Thursday. In the event of a tube strike will I be able to travel on the 205 bus from Kings X to Paddington?
I don't know about ticket acceptance although I'd doubt it will be valid.
Bear in mind that it'll be practically impossible to board buses as they'll be packed. You might find it quicker to walk from Kings Cross to Paddington.
TUC
11 Nov 2010
In other tube strike days recently it was noticeable that TfL did not make clear whether cross-London rail tickets (and ones with u1 rail travel etc.) were valid on buses, which really isn't acceptable. TfL seem to go to a lot of effort to address commuter needs, and forget about those travelling from further afield.
Hadders
27 Apr 2011
Not a walk I'd like to do on a hot day. Must be about 3 miles and an hour's slog on foot. Bus or cab I'd say.
Have you any experience of getting a bus or a taxi on the day of a tube strike?
It'll be quicker to walk unless you're very, very lucky.
cactustwirly
10 Apr 2013
Thanks for the advice, suppose I'll be walking then.
In the meantime I will hope that the strikes are called off
nicobobinus
16 Oct 2011
NE London
The 205 is one of those routes that typically sees extra buses on strike days, primarily because it shadows a large section of the Circle/H&C Line. The majority of these extras are scraped together from any firms able to supply buses and drivers, i.e. often well out of town, and their drivers aren't briefed to worry about fares. Although not officially so, they are in effect free to use as no Oyster technology is carried on them to validate cards.
If you were to find your way to one of these buses on a strike day with a maltese cross ticket I don't think you'd have problems. They don't load outrageously either.
Timewise in your shoes I'd allow at least an hour outside of peaks, preferably longer - during peaks all bets are off.
Google suggests 2.7 miles and 55mins. You mightn't even miss your suggested service if you're lucky as that's not a lot more than the minimum interchange time.
bb21
Emeritus Moderator
4 Feb 2010
The 205 was one of the two routes that evolved from the old Station Link routes, connecting mainline terminals in the northern half of central London (the other being the now withdrawn 705 for the southern half). Its importance when there are strikes on LU being self-evident for that reason.
Mojo
7 Aug 2005
Although despite what one might believe from reading this forum, customers making cross-London transfers between two National Rail stations are such a tiny percentage of people using the Underground system at any one time ;)
fandroid
9 Nov 2014
Hampshire
Don't forget that there is a strike on First Great Western too. However, their map shows that for services to Twyford 'most services will run'.
AM9
13 May 2014
St Albans
Just remember that pollution along the Marylebone Road is way above the EU limit and probably the highest in the UK.
Hadders
27 Apr 2011
You don't have to walk along the Marylebone Road! Other routes are available.
fandroid
9 Nov 2014
Hampshire
I have explored the parallel routes several times - at least as far as Marylebone station. If you cross over and go through St Pancras and out of the side exits there, there are quiet streets going west. The biggest problem is getting over the railway lines coming out of Euston, as the first bridge is a fair distance out (if wanting to stay parallel to Euston Road). Once past that it's not far to Regents Park, which is a great way to walk and has paths going west. However, you have probably set off by now and any advice is no use! catch a bus!
Haywain
3 Feb 2013
However, the route along Marylebone Road is the most direct. I walked that way last night and it took me 40 minutes, but I was walking fast. To no avail though - it needed to take 30 seconds less to have been worthwhile rushing!
BurtonM
3 Feb 2014
Manchester
Does the cycle hire scheme extend as far as Kings Cross?! I'm sure I've passed Paddington on a Boris bike before.
Hadders
27 Apr 2011
Yes it does, several docking station near to the station.
TUC
11 Nov 2010
Compared to the levels of pollution that Londoners had to cope with until the 1950s, somehow I think modt people have nothing to worry about.
