As someone who does similar journeys from Chelmsford. I can appreciate the x00 and x30 inter city being off limits unless reserved. But connection times are OTT, and their should be more flexibility on taking local trains that are not reservable.
But Advance tickets aren’t designed to allow flexibility. The whole point of them is a fixed itinerary - agreed to in advance - in return for a cheaper fare.As someone who does similar journeys from Chelmsford. I can appreciate the x00 and x30 inter city being off limits unless reserved. But connection times are OTT, and their should be more flexibility on taking local trains that are not reservable.
Good point, LU clearly couldn’t be booked/reserved in the same way as National Rail services but as you still get an indicative itinerary for that leg of the journey you could print it out in the same way and I’d expect to have to follow that but more as a time period in which to complete the leg rather than a specific LU train or trains to catch.How would (or even how could) compulsory reservations work on advance tickets where the origin was on LU?
For example, just last week I purchased a London Underground 1-4 to Manchester Piccadilly Advance (obviously with a reservation from Euston).
It's similar on a Sunday if you're coming from South Wales and want to head down the coast: a four minute connection isn't officially enough at Crewe, though it's usually doable, so you need to wait another hour for the next train.Same problem regularly at Crewe, arriving off the TfW at **28 and having to let the **31 to Liverpool go, and wait for the **57. Very frustrating, but I suppose it's only half an hour in my case. Ludicrous if it's over an hour.
There is no time restriction on the Underground.In the confirmation I received, Avanti didn’t give any times on their itinerary relating to the first leg (see image).
Going off-piste a bit here, but with this ticket what is the Delay Repay / entitlement to travel on the next service situation in the event of a delay on the tube. Also is travel before 9.30 permitted?
I don't know which station you are boarding at, but it may be prudent (or even essential) to depart before 0930 in order to have sufficient interchange time at EUS.
I agree, but the itinerary that Avanti gave them doesn't actually state any of that and just lists the LU arrival and departure times both as 1040. Even if it showed an arrival at Euston of 1025 - to give the 15 minute connection time - it would be an improvement but, as it stands, seems to suggest that they can leave their origin station at 1040. I wonder how many people do that - thinking they can't leave any earlier as it's an Advance ticket - and then find themselves missing their train from Euston?You need to plan to be at Euston no later then 10.25 in order to catch your train from there at 10.40. This is because Euston has a 15 minute minimum connection time. Based on the current TfL journey planner data there is an 10.08 Northern line service from Finchley Central which arrives at Euston at 10.25 You would need to ensure you are at Finchley Central in time to catch the 10.08 in order to have a valid itinerary and be covered in the event of any delays getting to Euston.
Also, I'd check the TfL journey planner nearer the date of travel for the most accurate data in case LU change their times slightly.
Provided you allowed enough time (see my previous post about the latest time you can start the tube leg of your journey by) then AWC are obliged to accommodate you on the next service to Manchester. It is NOT for you to prove to them the delay occurred in order to be afforded your rights. However, collecting some proof, like a photo of a departure board or similar showing the tube as delayed or cancelled, or asking a member of tube staff at the time to confirm the delay by writing on the back of your ticket or a screen shot on your photo taken at the time showing the tube as disrupted on an official website can be useful.
My understanding is that LU will only compensate for delays of 15 minutes or more to their services (i.e. an actual 15 minute delay on the tube and not say a 5 minute delay on the tube that caused your to arrive at your overall destination on the National Rail network 15 or more minutes late), and as they are not part of National Rail, the compensation they pay out will be based solely on the cost of the tube leg of your journey and not your overall cost of your journey. This is totally different to how it would work for a journey between two stations on the normal rail network.
Also as you booked through Avanti direct you won't have had access to the seat selector, and the allocated seat may not match preferences, so you may want to give yourself plenty of time to board, to find an alternative seat if yours isn't any good.
If Avanti was able to sell the ticket to you why was it not possible to book the same on Trainsplit? That doesn't sound right.
It is a grey area; where a ticket states "TOC & Connections", travel is allowed on appropriate connecting trains.
(my bold).If the ‘Route’ also states ‘and Connections’, travel is allowed on appropriate connecting trains where shown on the ticket(s) or other valid travel itinerary
But that could be taken to mean any valid connection that could be offered with that itinerary, for example if you make a journey from Manchester to Brighton and you hear that delays are occurring at St Pancras, it would make sense to go to Victoria instead. Clearly there is no intention that the "connections" part should be restricted by GTR train.You only quote part of the condition:
(my bold).
I agree with you about pragmatism and staff being sensible (and I've only been denied travel once- from Hemel on an EC&Connections ticket Hemel to Newcastle, taking a slightly earlier train), the conditions do say you must take the trains shown on your tickets or an itinerary. The T&Cs don't provide for pragmatism; if staff show sensibility it's always a bonus and not a right.
