Aberdeen - Birmingham Saver Return
Jord
21 Jun 2007
Aberdeenshire
Well this month, I may be heading south at some point and my ticket will be a Aberdeen - Birmingham saver return although I would like a all-nighter at Carlisle chucked in too.
I know, Outward the ticket is only valid on that day, but return, is it allowed to say if I did a Birmingham - Carlisle, did a all nighter at Carlisle, then Carlisle - Aberdeen the next day?
Cheers, Jord
me123
9 Jul 2007
The thread title's wrong: it's telling me you're going to Barnes ;)
AIUI, you can break a return journey on a Saver and complete it (reasonably) within the month it is valid for. ie, you can take a month in theory for a journey provided the dates on the ticket are valid.
You can go BHM-GLA/EDB-ABD no problem and, provided your ticket is valid for the days (which I imagine it will be) then you should be fine, Jord :)
Jord
21 Jun 2007
Aberdeenshire
:oops::oops::oops:
The wrong thread title, everytime I ask anything, I get at least one thing wrong, I blame being a brummie :lol:
Anyway, cheers for your help Chris :)
My itinerary would be something like:
Southbound: Aberdeen - York/Peterborough - Birmingham.
Northbound: Birmingham - Carlisle - Newcastle/Edinburgh - Aberdeen.
hairyhandedfool
14 Apr 2008
Unless these an easement in place I can't see a Aberdeen-Birmingham saver being valid through Peterborough, Grantham would be the furthest south on the East Coast Mainline I think. Nor can I see it being valid between Carlisle and Newcastle on the return, unless there is an easement.
Jordy
9 Jun 2005
WCML South
This is a polite reminder to use proper titles and not three letter codes, this will then avoid confusion with things like BNS (Looks like Birmingham New Street, but as me123 already pointed out, that is the code for Barnes!)
Cheers
Jordy
hairyhandedfool
14 Apr 2008
Apologies, I thought we had established where people were going from and to. Have edited post above for clarity.
me123
9 Jul 2007
I'm checking the routeing guide: Allows to go through the following maps:
BG+ER, BP+BS+FC, BP+BS+GA, BP+BS+ZZ, BS+FC, BS+GA, BS+ZZ, CE+BS+FC, CE+BS+GA, CE+DG+ER, CE+ER, CS+MM+FC, CS+MM+GA, CS+MM+WG+FC, CS+MM+WG+GA.
Long list :shock: in short, if you wanna go up the ECML
  • Go to Grantham and up from there should be fine.
  • PBO is not allowed I'm afraid :( Unsurprisingly, neither is PTB ;)
  • You can go to York via Sheffield (if there's a XC HST on that could be a good bet...)
  • It's not showiing map HX at all which means CAR-NCL is out I'm afraid. Odd that one, though...
It seems you can go up the WC to EDB or GLC and up from there. Or up the East Coast provided you join a train between Grantham and York inclusive. This is my interpretation of the many maps offered, I am open to corrections if anyone can find any different.
Jord
21 Jun 2007
Aberdeenshire
Thanks again Chris.
But twice i've gone via Peterborough now where I had a stop of 3 hours for the Freight and no one has said nothing, but I think I will do the Edinburgh - Plymouth HST on a Friday anywhere, hoping for some Valenta thrash :)
me123
9 Jul 2007
As usual, there's a difference between what's said and what's done... I know Hamilton - Coatbridge tickets are not valid via Glasgow but I've never been questioned either, even when I buy on the train. I suppose you'd be able to cross Carlisle-Newcastle as well in practice; I do find it odd that that route isn't in the guide :?
  • PTB is not allowed I'm afraid :(
Why would Pentre-bach be allowed anyway? :-? :p ;)
To clarify, 3-letter codes should not be used in titles, but there is no rule against using them in posts but please ensure they are correct.
I don't see a problem using codes as they can be used on:
- NXEC's booking engine
- Live departure boards
- National Rail journey planner
and can easily be looked up if people are unsure what the code is.
me123
9 Jul 2007
Sorry, Yorkie, I do that one all the time :roll: PBO it is, isn't it. Editted to avoid further confusion.
I've double checked PBO for you Jord, and technically speaking it's not allowed. Map BP, however, does allow travel to PBO from BHM but not any onward connections from there. Presumably for intermediate stations counted as Birmingham routeing point. But map BP cannot be used in conjunction with map ER (ECML) or any other similar map. :( As you've said, though, you've used it many times before so I don't see why you can't continue to do so.
Similarly, I can see Northern conductors allowing you to use the Tyne Valley line to get an HST to Aberdeen no problem, even though it's not in the routeing guide.
rail-britain
12 Aug 2007
You might find it is just as cheap to break the entire journey into smaller chunks
I did this when I was travelling Cumbernauld to Kettering
I bought :
Cumbernauld - Falkirk
Falkirk - Crewe
Crewe - Derby Return
Derby - Kettering Return
Crewe - Euston FC single
Euston - Glasgow FC single
Glasgow - Cumbernauld
That was the same price as
Glasgow - Crewe Return
Crewe - Kettering Return
Crewe - Euston Return
m8internet, sorry but I don't understand that post, where does Euston come into it? did you need to go to London and Kettering?
rail-britain
12 Aug 2007
I found it was the same price...
Crewe - Glasgow
as
Crewe - Euston
Euston - Glasgow
I therefore decided to go for the longer option!
