Tarquin88
First time post, in advance of a journey. Have read posting here by MikeS8 dated 18/05/19 about "Refund on inbound and outbound..." which I found helpful.
Two planned trips in next month:
Basingstoke - Blackpool North (Mon-Fri) 0548 ex Basingstoke changing at Wolverhampton and Preston, arrive 1047. Return same day on (probably)1727 ex Blackpool North changing as above, arrive 2209
Basingstoke - Liverpool Lime Street (Sat) 0540 ex Basingstoke changing at Birmingham New Street, arrive 0940. Return same day on (probably) 1806 ex Liverpool Lime Street changing at Wolverhampton, arrive 2208
I do not wish to stay overnight to lower the cost, am buying standard off peak tickets at short notice for maximum flexibility and don't want to travel via London. I have a rough idea of the "compensation" process if there are delays on the return journey - but might need some help from here.
My enquiry is about delays on the outward journey. You will see from the proposed itinerary that the time available at both destinations is relatively brief (and there's a bus journey as well). It is, however, sufficient for my purposes - if I get there on time. My question is: is there a minimum delay point at which I could decide to abandon the outward journey (because I wasn't going to get enough time at my destination), return home and get a full refund so that I could make the journey another day?
Thanks.
Thanks.
