A.W.S. Sounds on modern rolling stock?
Chrius56000
18 Aug 2010
Walsall
. . .Ever since second–generation traction and multiple–unit rolling stock (beginning with the prototype class 140 DMU) was introduced in 1981, A.W.S. equipment has used electronic sounders that gives a distinctive loud "ping" as an exponentially–decaying 750Hz note for "clear" (I saw it described as "750 Hz chime–decaying" in one of those horrendously expensive scientific papers once!), however, in the past two years I've certainly been on some modern (possibly Siemens–built) EMU stock that makes a most peculiar noise for "clear" – sometimes it sounds like "wheep!" and at other times I've heard a noise so ghastly for "clear" that I've begun to wonder if somebody's rigged up a tawny owl to the A.W.S. equipment for "clear" and the sounder's operating voltage electrocutes it!
. . .Can anyone with any technical knowledge tell me anything about the ghastly modern A.W.S. noises you get on some very recent M.U. stock?
Chris Williams
D365
29 Jun 2012
To the best of my knowledge. Most of the ”Enhanced TPWS” sounder units use wav audio files. For Siemens units, this would be applicable to later Desiro builds.
Nym
2 Mar 2007
Somewhere, not in London
They do indeed.
And thank you for calling it the correct, "Enhanced TPWS".
The WAV Files are downloaded from the RSSB.
There are also some very "Questionable" HMI choices that have been made with regards to POST sounding, etc.
