A strange computer problem has just affected my HP Pavilion desktop.
Xenophon PCDGS
17 Apr 2011
Today, when I was on the Quizzes and Games forum, I typed a station name commencing with "P" and this brought up the "Print" box shortcut and the name typed of the station did not have its commencing letter "P". I have Microsoft Edge on my system with up-to-date Windows.
Can anyone shed any light on the matter?
daveo
13 Dec 2015
Perhaps you were accidentally touching the "ctrl" key - ctrl+P = print.
You must have knocked the control (CTRL) key
Control and P is a keyboard shortcut, has been around since before windows 95, and still exists if you don’t want to use mouse version, these quick shortcuts existed before mouse was added
gswindale
1 Jun 2010
Occasionally I've seen similar on desktop keyboards in offices - my solution tends to be to press a lot of the keys such as "shift", "ctrl" and "alt" a number of times as the key may have got stuck! Generally the cause is a crumb or something!
JamesT
25 Feb 2015
There’s also the Sticky Keys functionality, for occasions where you do want to press one key at a time. On Windows pressing Shift 5 times activates it.
Busaholic
7 Jun 2014
Thanks for this advice. I shall be more careful. Hope this is nothing to do with me being 77..:oops:
Even if it was, don't worry about it. The fact you recognised what had happened and were able to articulate it shows you haven't lost your marbles. :)
dgl
5 Oct 2014
At least you didn't knock a glass of water over on the same table as a not that cheap laptop, causing half the keys to no longer work and currently not being able to find a replacement, thank god for the touchscreen and the on screen keyboard!
