A Question for Drivers
DaleCooper
2 Mar 2015
Mulholland Drive
Today I saw an EWS Class 66 being reversed onto some tankers, it was being driven from the front cab which looked awkward as the driver had to lean out of the cab window. I wondered why the driver wasn't using the rear cab which, it appeared to me, would make the operation a lot easier. No doubt there is a simple explanation.
neilb62
11 Nov 2015
Darwen.
I always found it easier to propel onto stock from the rear cab, with a decent shunter its no issue.
It's a few years since I've driven loco's so I'm amazed its still allowed?
scott118
24 Feb 2015
East Anglia
He will be being backed onto the stock, by a shunter, as stated above. Maybe his mirror's were dirty/defective, which could be another reason, why the driver was also looking back, through the open window.
Can only take a guess, that they didn't want to change ends again, to carry out a brake continuity test, once coupled. To then continue onwards, from the same cab..
As a question, could there have been a fault that prevented driving from the rear cab? Would a loco be allowed to continue in service if one cab was inoperative?
contrex
19 May 2009
St Werburghs, Bristol
In the 1960s you used to see EMUs e.g. 2 x 4EPB, being reversed at Herne Hill. The driver would stick his head out of the trailing cab window and trundle the formation backwards out of one of the Down platforms, onto the Tulse Hill spur, past the crossover, then stop and wait for the points to switch over, and then bring it back into one of the Up platforms. I imagine the move would have been very inconvenient if the driver had to drive from the leading cab and change ends, since the spur is on a viaduct at that point. Unless a spare driver was available.
leomartin125
15 Nov 2015
North West
That sounds like exactly what the DB Cargo 66 drivers do at Swindon with the steel coil waggons. They shunt back and forth using the front cab as the driving cab...
MrPIC
30 May 2015
I am fairly sure the rule state a train must be driven from the leading cab (except if it is faulty etc), but I suppose with a shunter controlling the move it is okay, I only have experience of shunting in 08 locos which only have one cab anyhows, and in EMU's, where we would change ends when reversing the movement, even with a shunter present. Reverse was only to be used when uncoupling is what we were told!
scott118
24 Feb 2015
East Anglia
I'm pretty sure that, passenger trains, whether they are ECS or in service, have to be driven from the leading end. Freight on the other hand, are permitted to propel. I will stand corrected if that isn't the case.
http://www.rssb.co.uk/rgs/rulebooks/GERT8000-SS2 Iss 5.pdf - module SS2 - section 6 states -
You must drive from the leading cab whenever possible when making any other shunting movement. If you cannot do so, you may drive from another cab, providing a shunter can control the movement..
cf111
13 Nov 2012
I'm pretty sure that, passenger trains, whether they are ECS or in service, have to be driven from the leading end. Freight on the other hand, are permitted to propel. I will stand corrected if that isn't correct.
Would one or more of the Highland Caledonian Sleeper portions not be propelled at some point during the shunting operations at Edinburgh?
I've never actually seen it in action from the platform but it was just a thought.
Peter Mugridge
8 Apr 2010
Epsom
The Lowlander will also get a propelling movement; this would be at Carstairs in the up direction only as it is backed on to the rear of the portion from Glasgow.
tsr
15 Nov 2011
Between the parallel lines
ECS passenger units in multiple certainly don't have to be, if local instructions require it. There are one or two "two man shunts" remaining on the Southern network for trains without cab corridor connections. In this case the conductor (these generally happen where conductors will still be retained...) will be in the leading cab for at least one part of the movement, and control the movements of the train by means of buzzer codes - eg. set back / slow down / stop etc.
There are various permutations but it is done - maybe not even every week, but usually around a few times a month in my area.
TimboM
12 Apr 2016
Saw a DB Class 60 shunting at Northwich the other day and the driver stayed in the "front" cab as it reversed and I had a similar thought to the OP. However, did occur to me that with a long rake of wagons and reversing round a corner into sidings that the driver wouldn't be able to see whatever cab he was in and would be relying on the shunter either way.
FordFocus
15 Apr 2015
Regularly have a shunter on a radio system. The shunter doesn't necessary have to stand next to the train and walk along side it. They need to just be able to see the movement and the area is clear. If the radio goes dead (no talking or beeping) the movement stops immediately.
7 Jan 2010
Quite possibly
