Hi
I'm currently training with Avanti atm.
I'd like to hear the difference in answers if there are any, from qualified drivers any TOC.
When stopped at a platform, and you're on a single yellow, at the end of the platform.
You've closed the doors and you're good to go.
Next signal we will assume is a red. Stop signal.
Assuming good rail and weather conditions. So you will be at 15mph over the next AWS magnet at the next stop signal.
I understand, different line speeds and whether there are crossings etc before the stop signal will effect this answer.
1) What's the 'maximum speed' you would go 'up to' before that stop signal? Let's say it's a clear line, no crossings etc, and the lines speed is 100mph.
I'd also value advice on various 'maximum speeds' on different line speeds for question 1 please.
2) As a side question. When driving out in the sticks, 4 aspect, you see the double yellow and you need to be down to half line speed by the single yellow.
but if 3 aspect, you see the single yellow in the distant, what speed or reduction of speed do you like to get to as you hit the single yellow in preparation for the stop signal?
Mainly question 1. but thanks for any advice. cheers
