A query for any forum "computer wizards"
Xenophon PCDGS
17 Apr 2011
An elderly lady member of some eighty years vintage of a charity that I am currently assisting showed me the monitor screen of her HP tower system and the icons at the right side of the foot of the screen has one, with a red cross upon it, that appears to be for "Network and Sharing Centre" which when clicked, brings up a screen that starts "Connection status unknown...Server execution failed".
Her system functions perfectly in all respects, so has anyone any idea why this icon should be stating what it says ?
sutty
15 Feb 2011
Hi.
A couple of questions to boil things down a bit.
Which operating system is the PC running?
Have any changes been made to her wifi router?
asylumxl
12 Feb 2009
Hiding in your shadow
Has her computer been correctly added to the network? It seems she doesn't have sufficient network privileges but it may be that the network has internet sharing enabled.
Whoever administrates the network should check using the admin account this.
Wyvern
27 Oct 2009
Is she in fact on a network?
If everything is working OK I should let sleeping dogs lie.
Xenophon PCDGS
17 Apr 2011
Hi.
My wife and I have just called to see the lady in question, who responds to your query as follows:-
Windows Vista 32-bit (System already installed in the HP Pavilion tower system when it was purchased brand-new in 2009 from the John Lewis store at Cheadle Royal)
No changes have been made to her router (She uses a BT Home Hub 3)
Crossover
4 Jun 2009
I agree with Wyvern. If she is able to browse the Internet OK and everything works, I'd leave it be. Windows does occasionally do odd things (even for me on 7) where it thinks it doesn't have a proper Internet connection, but is indeed fine. Plus, Vista is the work of the devil <(
As it isn't an issue I have come across directly before (and I haven't had dealings with Vista for some time either), I have done a quick read round on Google.
This may be of some help, especially the post by seanatsalty about 2/3 of the way down the page.
That said, if you're not confident with running command prompts and such like and it refuses to work, I'd seek advice from someone who may be able to assist directly :)
sutty
15 Feb 2011
Thanks for that information. The next question would be (and I neglected to ask earlier (the joys of a crying 4 week old boy)) - can she access the internet?
The error provided, I have seen in the past when trying to share media via windows media centre. If she is indeed able to access the internet, I'd ignore it.
Should she not have an connection to the internet, I would recommend
1) Reboot the home hub - any changes after that? If not
2) If you open the networking icon on your PC you should find a link that says "status", clicking on that will open a smaller window where you will find a button to diagnose and repair your connection. Should this fail
3) If you open the networking centre via the same icon, you will have a bank of text to the left of the window. Open that, right hand click on your wireless network and then "remove network". You will then be free to re-associate with the home hub.
If none of these work, I'm more than happy to try to assist further :)
Xenophon PCDGS
17 Apr 2011
Many thanks to a fellow forum member. I can confirm that she does have full internet access (15.7Kbps) and because at her age, just a few standard programs suffice for her use, especially just for browsing for general information. She has the basic BT "up to 10GB monthly allowance" of which she seems to average 4.6 GB usage per month.
I have advised her to ignore the small item with the red cross on it at the foot of her desktop.
My sincere thanks to other forum members for their postings.
Crossover
4 Jun 2009
My bold - Kbps? :shock:
Yes, I would definitely advise to leave well alone in which case. I have often seen Windows display the red cross on Network and Sharing Center despite being connected fine.
Bungle73
19 Aug 2011
Kent
Sorry...will clarify.
I carried out a BT Wholesale speed test on her system which shows:-
Download speed.....15.7 Kbps
Upload speed.........0.82 Kbps
Not bad for our area using the BT basic system.
That's not right at all - that's a lot slower than dial-up. Are you sure you don't mean 15.7Mbps and 0.82Mbps? That would make a lot more sense
asylumxl
12 Feb 2009
Could well mean kilobytes per second rather than kilobits per second. In which case it would be roughly a 0.15 megabit connection.
SS4
30 Jan 2011
Kbps is kilobits per second, this should not be confused with KBps which is kilobytes per second - there are 8kbps in 1KBps. 15.7 Kbps is roughly 2 KBps which is very slow. I'd expect it to be about 100x faster or about 2Mbps. It just seems very slow
Of course it may just be your area sucks for internet of course in which case please accept my apologies for doubting you
michael769
9 Oct 2005
She needs to call her provider, that speed is far below the Openreach fault threshold.
I'm surprised the tester managed to run.
Xenophon PCDGS
17 Apr 2011
Someone told her that her residence, situated where it is in a very rural part of the Bollington/Adlington/Pott Shrigley triangle, was too remote to have a fibre optic connection installed. Is this a normal situation in remote rural locations ?
My own knowledge of computers and their connections is minuscule, hence the reason why I set up this thread at the age of 68, knowing full-well there are forum members with up-to-date knowledge in this area.
michael769
9 Oct 2005
The fibre rollout is far from done and many populated urban areas are years away from seeing fibre let alone rural areas.
Nevertheless her speed is pathetic for ADSL and is low enough to be considered as defective by Openreach. It is possible if she is very remote that she is on an exceptionally long line in which case it may be preferable to migrate her onto a fixed rate ADSL product or even ISDN to get a better speed, because her current speeds are not worth the money she will be pending.
But first steps are to engage with her ADSL service provided and get them to investigate if there is a fault.
I am assuming as you mention a BT Home Hub that her service provider is BT. The best way to get help and advice for BT internet connections is to post on http://community.bt.com/t5/BB-Speed-Connection-Issues/bd-p/BBinHome.
In the meantime she needs to ensure that the Hub is connected and switched on 24 hours a day. Modem disconnects or power offs are the biggest single causes of low connection speeds.
Xenophon PCDGS
17 Apr 2011
May I thank you for your extra input, which will be taken up with BT.
With regard to the BT Home Hub 3, I can confirm that the elderly lady has this unit permanently connected at all times and it is very near to the main BT socket and her tower system is in the same room as the BT Home Hub 3.
Crossover
4 Jun 2009
I was going to ask whether the router was far from the PC, as you describe the type of building in the OP, signals can degrade. But if it is in the same room it is unlikely.
I use www.speedtest.net on both PC's and mobiles to test the speed, from which, you can post a link of the result. Would it be possible to do such?
Xenophon PCDGS
17 Apr 2011
My wife and I drove to her house when we saw your posting and I used the speedtest system stated in your link, which revealed a set of readings as follows:-
Download...9.97 Mbps
Upload.......0.81 Mbps
michael769
9 Oct 2005
Upload...9.97 Mbps
Upload...0.81 Mbps
It is not possible to upload at more than about 1.2Mbps with ADSL so I presume that the 9.97 figure is a download.
These figures are a bit more respectable for a rural line.
Xenophon PCDGS
17 Apr 2011
It was indeed a DOWNLOAD figure of 9,97. I was in such a rush to make the posting after driving the five miles there and back in a heavy rainstorm, that I was careless with my posting. 68 years of age and I still make childish mistakes..:oops:
My posting now reads correctly.
Crossover
4 Jun 2009
Sounds like everything is working well :)
