A Problem with 466 Networkers?
whhistle
30 Dec 2010
I was reading in the SouthEastern thread where someone mentioned the 466s and how they won't be PRM compatible because they don't have any toilets.
I wonder whether one/both ends could be made into a middle coach by taking out the cabs and fitting toilets? They would obviously need a lot of work to fit toilets anyway but would give more space if taking out the driving cab area and remodelling the ends to be through coaches.
Would this be worth doing?
Could they be added to Turbo units?
Seems a waste to send them for scrap.
a_c_skinner
21 Jun 2013
You don't need toilets for PRM I think. Look at busses for example. The loo issue is accessible toilets use a lot more space than old style train loos so you loose capacity.
It does seem unsatisfactory that we are withdrawing serviceable trains when almost everywhere is short of capacity.
Edit The wiki entry says DTOSL in one place and DTOS in another for the second vehicle. Is there a loo?
chubs
30 Oct 2012
The 376's don't have toilets either do they?
Nobody would spend that much money on old stock.
hwl
5 Feb 2012
Yes but not a "universally accessible toilet"* hence the need to couple to a 465 to provide a UAT (that has been retrofitted).
The seat /standing area loss in 2car metro unit given most are used in 6/10car combos rather than 2 car ~90% : 10% by current diagrams)
*DfT Lingo
Doomotron
25 Jun 2018
Kent
There's already a thread on this. There is a derogation which means they can be operated without PRM modifications as long as it is connected to PRM-modified stock (465s). This is fine as they mostly operate connected to them, but the branch lines could have some problems.
whhistle
30 Dec 2010
As Doomotron said, all the discussion on this has been here:
If you think this specific query belongs in a more general thread about (what I assume is) actual refurbishment (IE, not partial rebuild / diminishing the class), then did you report it?
I mean, if we're saying it's a good approach to have units coupled together nearly all the time, why didn't London Midland order 360s, or Scotrail order non-corridor door stock to save the hassle of not being able to see signals?
I'd suggest the answer is, because it's not ideal to run units coupled together.
Hence the suggestion about converting them to mid-coaches, not just a "refurbishment".
Class 466
5 Mar 2010
Atherton, UK
Given they already spend most of the time attached to 465s it doesn’t really make much difference.
