A new computer problem.
Xenophon PCDGS
17 Apr 2011
Rather annoyingly, when I am typing out correspondence, any new sentence that commences with the capital letter "P" causes the "print drop-down box" to appear and the capital letter not appear and everything comes to a dead stop until I cause the offending drop-down box to be cleared.
I am using Microsoft Edge on my large memory capacity HP Pavilion desktop computer. I am 80 years of age and would welcome any advice why this is happening.
McRhu
14 Oct 2015
Lanark
Is there any chance you're hitting CONTROL-P or COMMAND-P instead of the shift key?
McRhu
14 Oct 2015
Lanark
Not sure then... What software (ie - App) are you using to type your correspondence or did you mean you're using an online text editor accessed via Edge itself? Whatever the case (assuming the keyboard is properly functional) there might be something within the settings menu that could be reset.
Darandio
24 Feb 2007
I believe it's some sort of sticky command that has inadvertently been activated. From memory either pressing CTRL twice in succession or holding down both CTRL keys used to release it.
LYradial
8 Jun 2024
welsh marches
Occasionally suggests to me a keyboard problem, in my working days I would have swapped out the keyboard and cable as a starting point but this is not realistic.
you could try unplugging and reseating the cable, or giving the keyboard a smart rap on the desk
looking at hp desktops it may be a wireless keyboard so that’s another problem, I’m showing my age here but still think the keyboard is a likely suspect
Crossover
4 Jun 2009
I would agree that keyboard may be the issue. Although it doesn’t explain why it doesn’t do it with other keyboard shortcuts
It’s not unknown for me to try and fix these issues by, with the pc off or keyboard disconnected, pressing over all the keys on the keyboard to make sure nothing is stuck down at all
Xenophon PCDGS
17 Apr 2011
Another problem has now arisen. Occasionally, when I type the name of a settlement beginning with a capital latter such as Dumfries, what appears is an extra capital letter at the start which then might say BDumfries. Whenever this occurs, those first two capital letters are nowhere near to each other on my keyboard.
styles
7 Dec 2014
Gwynedd
Sounds like a 'key rollover' problem. Normally these problems would be a feature from day 1 of owning the keyboard as it would be down to the keyboard design, but as this has developed over time, either a hardware problem perhaps with some small amount of residue joining different parts of a circuit together, or a driver which has somehow ended up corrupted or lacking in updates or something.
There's various Windows features like 'sticky keys' which might cause some problems, but none which would cause e.g. Dumfries -> BDumfries that I can think of.
Try a different keyboard if you have one; or try that same keyboard in another computer. I suspect it'll be a case of going keyboard shopping unless you can find some dirt hidden under the keys and clean it out!
Xenophon PCDGS
17 Apr 2011
My eldest twin son has just called and taken away the "problem" Microsoft keyboard that worked off my HP Pavilon tower system of my desktop computer and replaced it with a good quality HP keyboard. He has run a program to check if there were any system problems and all is now clear on both fronts.
Thanks to everyone who made postings upon this thread and for the advice they offered.
Royston Vasey
14 May 2008
Cambridge
Reminds me of the announcements on the 365s which sounded remarkably like "BLondon Kings Cross"
