Xenophon PCDGS
If the numbers four, six, seven, eight and nine can all be suffixed with "teen", what was the number that makes the word "umpteen"?
It doesn't derive from a number, rather the "ump" comes from the use of "umpty" and "iddy" as colloquial shorthand for dashes and dots in Morse code.If the numbers four, six, seven, eight and nine can all be suffixed with "teen", what was the number that makes the word "umpteen"?
Only the French do that - check out Switzerland and Belgium!If I can ask another number question?
The French word for 7 is 'sept', and 17 is 'dix-sept'. Why is 70 not 'septante', in the same way as 40 is 'quarante', 50 is 'cinquante' and 60 is 'soixante'? It is effectively '60 + 10'. Ditto 80 which is '4 x 20'.
There probably is no answer - it is the French after all, but it always struck me as strange.
In Belgian and Swiss French they do use Septante, Huitante (I believe Belgium retains Quatre-Vingts here) and Nonante but "French" French sticks with the vigesimal (based on 20) sixty-ten, four-twenties and four-twenties and ten.If I can ask another number question?
It’s a linguistic relic of a 20-based counting systemIf I can ask another number question?
Roman influence again...Shillings in a pound had a base of 20, but pence in a shilling had a base of 12.
Anyone know if the word 'umpteen' was previously in use prior to the early 20th century, with some different meaning, before its more recent use meaning that of an indefinite largish number?If the numbers four, six, seven, eight and nine can all be suffixed with "teen", what was the number that makes the word "umpteen"?
Would I be right in thinking there was a TV advert about 40 years ago that used that "umpteen" word....."Mr Sheen shines umpteen things clean"?Anyone know if the word 'umpteen' was previously in use prior to the early 20th century, with some different meaning, before its more recent use meaning that of an indefinite largish number?
Yes. The (1980s?) one I've located online, however, certainly hasn't aged all that well, and likely wouldn't be aired these days.Would I be right in thinking there was a TV advert about 40 years ago that used that "umpteen" word....."Mr Sheen shines umpteen things clean"?
Is there not an “octante” variant as well?The use of soixante-dix and quatre-vingt-dix is a remnant of the old Celtic system of counting on a basis of twenties. Most numbers later went over to the Roman system based on tens, but these stuck. Septante and nonante are used in Belgium and Switzerland, but they use quatre-vingt-dix except in a few areas of Switzerland where they still use huitante.
My Shorter OED says "early 20th Century"Anyone know if the word 'umpteen' was previously in use prior to the early 20th century, with some different meaning, before its more recent use meaning that of an indefinite largish number?
There absolutely are those people, and they will spend time & effort checking them in detailOn a tangent, does anybody ever verify the primary source of such etymology claims?
I'd love to think there's someone in the OED office just working through old surnames and plausible-sounding publication titles, scribbling, "First recorded usage, The Dolomite Chronicles by Alistair McThurso, c.1817". "Yeah, that sounds good, let's use that!"
Yoy need the help of someone like Susie Dent (Countdown, Channel 4)On a tangent, does anybody ever verify the primary source of such etymology claims?
