A ticket like this, through London, is valid via all the routes from origin to London,
plus all the routes from London to destination.
So I think that I can confidently say the answer is that you can do all of the things you wish without checking,
but I will check...
Direct trains are always valid (none in this case).
The shortest route on regular services (inc. routes up to 3 miles longer) is always valid (good luck working those out, it's tricky to do as you'd have to look up the routes to the various London Terminals. Railmiles does help but it doesn't know which routes have regular services. You are supposed to use the NRT but this would take many hours for a journey like this!)
To determine mapped routes:
The Routeing Guide (RG) is here:
http://www.atoc.org/about-atoc/rail-settlement-plan/routeing-guide
Routeing Point (RP) identifier:
http://www.atoc.org/clientfiles/File/RSPDocuments/routeing_point_identifier.pdf
Aylesham has 4 RPs, 2 of which are appropriate for this journey, Faversham & Ashford Intl.
Shirley has 2 RPs, both are appropriate for this journey, Stratford U Group & Tyseley.
Permitted Route Identifier:
http://www.atoc.org/clientfiles/File/RSPDocuments/permitted_route_identifier.pdf
Stratford U Group to Faversham is valid via the following maps:
LONDON BB+WX+LR CS+LR
Stratford U Group to Ashford Intl is valid via the following maps:
LONDON
Tyseley to Faversham is valid via the following maps:
Tyseley to Ashford Intl is valid via the following maps:
LONDON
LONDON = maps from origin to London + London to Destination (and vice versa)
London Group to Faversham is valid via the following maps:
DV+VC HK LD LR LR+SL NK
London Group to Ashford Intl is valid via the following maps:
HS LB+SD+LK LK LK+SL LL LR+SL
London Group to Stratford U Group is valid via the following maps:
BB+WR BB+WX GC
London Group to Tyseley is valid via the following maps:
GC TV+WM
Maps:
http://www.atoc.org/clientfiles/File/RSPDocuments/maps.pdf
- Enjoy!
- If I could use HS1 (since it seems that the fare is the same not via and via)
I don't understand what's in the brackets. HS1 is a permitted route between Ashford Intl & London and also between Faversham & London.
- Would I be able to go via Chiltern (i.e. Marylebone - Moor Street - Shirley)
Route High Wycombe is £48.00 for an SVR. If you get this ticket and travel via High Wycombe and on your way back you decide to return via the WCML or via Oxford, then you should be charged an excess of £6.80 (the difference is £13.60 and you pay half that to change the route on one portion only).
- Would I be able to start at Birmingham International on the way back? (technically speaking its in between Shirley and Aylesham and the ticket price is the same!)
Providing Birmingham Intl is on a permitted route between Aylesham and Shirley, yes you can. (To check that, consult the maps above)
(obviously not the first two at the same time though! although for the second one I couldn't find any tickets for that route on the Southeastern Website!)
Sorry, you lost me!
The cheapest fare that I seem to get is 61.60 (excluding advance fares!)
Route +High Wycombe SVR £48.00
Route +Any Permitted SVR £61.60
