A 2-coach c2c service?
6 May 2017
Near a bunch of sheds that aren't 66s.
On the c2c twitter feed it says the 20:40 Grays to London Fenchurch Street is formed of 2 coaches instead of 4 due to vandalism.
Obviously they run a fully EMU fleet, so how does this work? I can't imagine they ran a 357 with two coaches taken out (where would the panto be?!) - did they mean they locked two coaches out of use .. It's the best answer I could think of but surely more informed will know?
I tried attaching a screenshot but because I am on my mobile it is being a pain. I am sorry about this.
6Gman
1 May 2012
Presumably two coaches locked out of use.
Larry Trapp
18 Nov 2018
Never heard of them taking coaches out of a EMU set so guess the Vandalism is internal, seats ect.
I think you are correct that they have locked those coaches oou.
Must be bad though to lock out the coaches.
RTT says the service (1W48) was pathed as a 357, don’t know the route, is that the usual traction?
pdeaves
14 Sep 2014
Gateway to the South West
Shortly after GWR introduced its 800s, I remember a train advertised as 5 coaches. However, it wasn't an 800 but an HST with 8 passenger vehicles in the set. It wasn't on the screen incorrectly as the rear three were locked out of use.
700007
6 May 2017
Should be, 387s aren't booked to run via the Grays/Rainham loop in passenger service on a normal day.
Mollman
21 Sep 2016
Preston
Seen it on Virgin a few times, when an 11-coach 390 has one coach out of use journey check describes it as a 10-coach train.
Surreytraveller
21 Oct 2009
Might be someone's shat on a seat and it needs cleaning
387star
Why has c2c kept such a strange brand given the standard geographical brands favoured elsewhere
Why is the livery so dull?
Larry Trapp
18 Nov 2018
I remember reading something similar a few years ago, ISTR one Saturday night the driver of the Brighton-bound 377 arrived at London Victoria to find someone had apparately urinated in his cab and the seat was wet, he quite rightly refused to drive the train and the service was cancelled.
Mollman
21 Sep 2016
Preston
c2c seems to be a well know brand so why change it? Livery wise it used to have a nice simple blue livery but then it got 'corporateised' by NX into the same livery as East Coast and Greater Anglia. The Italians obviously don't have a new livery as high priority which is a shame as it is dull.
samuelmorris
18 Jul 2013
Brentwood, Essex
It's possible they might implement one when the 711s arrive as by then the 357s' white livery will be looking a little tatty, but it really depends how much of a priority they consider it to be.
tsr
15 Nov 2011
Between the parallel lines
Don't believe I've ever seen that - that's more likely a double Voyager subbing for a Pendolino.
The same message can be, and is, sent in both circumstances (ie. coach locked out or change of stock).
It won't be clear which it is unless you can see the internal information (or the TOC broadcasts it to the public by accident) - or if you turn up and notice which of the two things has happened.
Indeed. I have had several occasions where I've actually discovered someone's walked through a coach puking everywhere (or similar, or worse) and done the same in the next one as well, so more than one has had to be locked out.
It can also be that certain technical defects would need more than one coach locking out of use.
This happens fairly regularly. Unfortunately, passengers on the BML have developed a slightly bizarre habit of thinking that intermediate cabs on Electrostars in multiple (which, in the case of 377s/387s, have a gangway through them) are actually the toilets.
(For those not familiar, the cab doors slide across to block off the cab areas and allow anyone to walk through the middle of the attached cabs, from one unit to the next.)
This is not a cultural problem from passengers who aren't local, such as those boarding at Gatwick or the ports, and not being familiar with the trains; rather, it tends to be people who have drunk a bit too much late at night and try to open anything which looks like a door to see if it's a toilet.
The cab doors are plastered with copious "staff only" warning notices and are clearly not for public entry, let alone for use as a toilet. It's also patently obvious that the things are not toilets once you go in there. Regardless, people still try to force the doors, and occasionally succeed, if they're really violent. They then go in there and... go in there. If you see what I mean.
If they don't succeed, they don't generally tend to walk further down the train to look for the actual toilets. Instead, they tend to just go on the floor of the gangway. This also renders the cabs unusable.
When the trains then detach at a terminus, at least one driving cab is then out of order.
Fleet Control have actually developed a sort of Tetris game plan where they try to position the train so that it is adjacent to a platform on the relevant side where the cab seat has been soiled. This then allows fitters to access the cab and dismantle the seats (once basic cleaning has been carried out). They will then remove them onto the platform, where possible, to allow replacement or for the train to be driven to the depot. Sadly the fabric is fairly thin and the residue typically leaks into the cushions, which themselves are quite firmly attached to the seats.
TurbostarFan
8 Aug 2016
Why not simply leave everything it in its place and (once basic cleaning has been carried out) just drive the train into a depot? Seems a bit more efficient then potentially having to close off a platform as well!
