92044
Turbostar
15 Aug 2006
Plymouth, Devon
These days, for some strange reason, it's cheaper to transport rolling stock needing attention etc., by road, than by rail. Obviously, sounds like it's come from Crewe, & being a Brush product, my guess is it's heading down to Brush Loughborough.
bluenoxid
9 Feb 2008
If it goes kaput in the railways there is a lot of money to pay. If it falls off the back of a wagon, well you just have to ring Sally Traffic and wave at the irate motorists
CraigS
2 Apr 2007
St Leonards on Sea
I believe 92044 is now owned by Eurotunnel as is a few other former Eurostar UK owned 92s so could it be enroute to Loughborough for overhaul for use by Europorte 2?
Phoenix
11 Mar 2008
birmingham
About time it's quite ridicoulous,locos which do such sterling work like the 92's should be anywhere but stored.
But yes it's most likely that it's been given a good old working over to remove years of dust before it starts it's new life with it's new owner's.
Let's put it this way if a 92 can pull two 37's another 92 a whole car train and then some cargo wagon's then really there isn't much they cannot do.
Please someone argue this.
westcoaster
4 Dec 2006
DTOS A or B
cant go over most of the network as there is no juice.
87015
3 Mar 2006
GEML/WCML/SR
Be much better on the overnights than skodas especially in autumn slippin and slidin' season, not sure what sort of mods would be needed to the ETH provision on 92s to make it 'normal' ?
class 313
10 Dec 2005
St Albans
But when 92s slip, oh they slip <D
37402
15 May 2007
No they were built for CHANNEL TUNNEL FREIGHT, but to haul the ill fated Nightstar trains from London to the tunnel IIRC, with the aid of a genny van!
No they weren't. 92's were designed as dual purpose locos - hence the ETS supply. The only reason they haven't been used on domestic passenger trains is the fact that the index is too high; something which wouldn't have been a problem with the Nighstar stock. Genny van's (which, incidentally are set up on the system as locomotives, Class 96 - hellfire!) were for the tractors.
87015
3 Mar 2006
GEML/WCML/SR
Genny van was for the 37/6s, 92s would have ETH'd stock directly AFAIK, with the nightstar stock obviously having non-standard (by UK standards) ETH supply.
class 313
10 Dec 2005
St Albans
37402
15 May 2007
No they don't. The lower top speed, lower gearing and heavier weight (an additional 40t when compared to say, a skoda) makes them *much* less prone to slippage.
Galvanize
8 Jun 2005
South East london
Oh. I did say "chunnel" freight and nightstar. I had assumed they had no ETS!
Thanks for putting it in the right direction though ;)
*calls taxi :p
class 313
10 Dec 2005
St Albans
What I meant was the slipping can get quite vicious! As felt on the Choppington Changer.
Nym
2 Mar 2007
Somewhere, not in London
You should see one starting off light, I thought the TWPS was going to stop it leaving p13 at MAN, got to linespeed in about 4 seconds!
