82xxx DVT how do they move?
railfan458sw
8 Sep 2021
iopjklnm1
If the DVT doesn't have traction motors and uses power from the 91 how is it moving? The 91 pushes but that means it is reversing?
superalbs
Verified Rep - Superalbs Travels
3 Jul 2014
Kraków
Yes, the 91 will simply push or pull, depending on the direction of travel.
transportphoto
Jobs & Careers
Quizmaster
21 Jan 2010
It’s a carriage which has been designed to have a driving desk with through wiring to the locomotive. All motive power is provided by the locomotive regardless of direction of travel.
norbitonflyer
24 Mar 2020
SW London
If the dvt doesn't have traction motors and uses power from the 91 how is it moving??? The 91 pushes but thst means it reversing
Like all modern traction, a class 91 can move as easily in one direction as the other (it even has a cab at each end, although the blunt end cab is rarely used) So yes it's pushing but it's misleading to say its reversing. The driver in the DVT is controlling the Class 91 remotely, just like any EMU with a driving trailer leading.
Western Lord
17 Mar 2014
Modern traction? Steam engines could (and did/still do) run in either direction!
dk1
2 Oct 2009
East Anglia
Time Division Multiplex. It’s how the DVT/DBSO & Loco communicate.
Easiest way I used to explain it is the Loco is the husband & the DVT is the wife. If they disagree they divorce (deconfigure) and then you continue as single (conventional).
185
29 Aug 2010
Consider a DVT to be just a box with a windscreen and a (duplicate) set of controls to tell the loco at the other other end to push the train backwards.
47827
3 Mar 2020
Middleport
Whilst I fully appreciate the reasoning behind them on the efficiency they brought it did water down the ride quality and increase lurching as pushing with that sort of acceleration and at higher speeds isn't the smoothest option. It's a good job nobody tried to get the sleepers operated with such a system in the end for exactly that reason although I'm sure it'll have come up in meetings and on suggestion lists over the years.
Cherry_Picker
18 Apr 2011
There's not much of a need to put a DVT on the sleeper, they don't need to turn around half a dozen times a day.
CyrusWuff
20 May 2013
Except the Chiltern Mk3s and ATW Mk4s, which have been modified to use the American AAR system which the Class 67s (and 59s, 66s and some 68s) are fitted with.
More importantly, the portion working of the sleeper would make reforming the DVT a right pain.
There is talk of using one on the Night Riviera as that doesn't portion-work - was mentioned as a possibility (but not certainty) in the article in Modern Railways about the proposed new locomotive order.
It'd not be helpful for Caledonian Sleeper.
Northampton
Night riviera would make more sense as it would remove the need for the second loco to attach/detach at Reading and get rid of the propelling move on/off Long Rock at Penzance.
C96
31 Mar 2018
Is there enough station length for an added DVT or would it be in lieu of a carriage.
Irascible
21 Apr 2020
Dyfneint
Not only that, they were quite capable of being controlled remotely too!
( as an aside how many autotrain control systems were there? the GWR used physical rods but I thought one of the others used some sort of pressure based system ).
Other than being run on a shoestring I'm slightly surprised it wasn't looked at before when the mk3 DVTs went surplus - wouldn't be the first time old TDM equipment was reused/refitted, & doesn't it use the PA circuitry?
hexagon789
2 Sep 2016
The LNWR used mechanical linkages with rods but the LMS adopted the vacuum system from 1927 and converted existing equipment.
The French used compressed Air such as on the seven-coach double deck steam push-pull sets used on suburban workings out of St Lazare.
RCH jumpers, which are used for controlling the lighting etc.
Though in early WCML days there were issues with signal degradation, so the Mark 2F and 3 stock used on the WCML was fitted with screened cables for the push-pull working.
Gloster
4 Sep 2020
Up the creek
I think that one of the Southern’s constituents used wires running along the roof. Even though the driver was at the other end of the train, there was still the fireman on the footplate.
