730 Abrupt Slowing
Class 323221
14 Jun 2024
England
Hello Everyone,
Quite often, when I am on the 730s, they begin departing out of a station or through what was a signal at danger. You can hear the traction motors as the train accelerates for a couple of seconds. Then the train slows down, the traction motors cut out after the train starts slowing, the brakes hiss and then the train continues on its way. It doesn't always become stationary, just very close to being stationary. I think it's a bit odd seeing as you can stil hear the motors. Does anyone know why this happens? I have a theory that it could be something like hill start but I'm not too sure.
Thank you
John Webb
5 Jun 2010
St Albans
Are these trains leaving a terminus station or one where they've been turned round? What you describe sounds like a 'Running Brake Test' which drivers must do soon after moving off from a terminus or other turn-round point to check all is working as it should.
800001
24 Oct 2015
Hello Everyone,
Thank you
Are you sure you are passing signals at danger?
Most likely a proceed aspect signal which changes to red once train passes it, you are then seeing the red signal.
AJDesiro
10 May 2019
Rugby
I believe there is (or was) an issue with the hill hold system where the system engages after the train has just started moving. At least that's what I overheard from a guard instructor training up some guards on the units a while back.
JLX5
4 Jun 2020
West Midlands
Still is the case. The brakes don’t fully release for some reason and the only way to get them to release is to go into coast and back into power, sometimes you don’t have enough speed to do this quick enough so you come to a stand and have to start all over again.
The extra hiss from the brakes that the OP is referring to is this process of going into coast and then back into power which makes the brakes fully release.
Alstom spent a good few months at the start blaming drivers but have since acknowledged it is a software issue with an update to address the problem supposedly being released by the end of 2024. Here we are over half way through 2025 still with nothing.
800301
29 Dec 2022
Essex
So this must be a common 720/730 problem as the Greater Anglia units do it but I’ve never noticed it on a 345
NSEWonderer
5 Dec 2020
I do hear that the 720s had an issue where if you didnt take full power from a standing start it wouldn't release the holding brakes properly and bring it all to a stop. I assume thats the issue 730s face? With 701s we first move the Traction brake controller into Coast and then into the appropriate power % after.
They've however been "fine so far with going straight into power" but its much more appropriate to bring it into Coast first before moving and then into power with the 701s. No clue how that will work on 730s or of they have a software specfic issue.
Does seem to be Alstom having a few brake related software stuff to fix on most of Aventras.
Class 323221
14 Jun 2024
England
I am definitely sure. The train comes to a halt and traksy confirms it's a signal at danger.
The times I have noticed it is at a station within the route, not a terminus.
I thought it could be this as you could still hear the traction motors. There is another post that also makes sense as well. Thank you for your help.
This makes a lot of sense. It does sound similar. Maybe the brakes aren't releasing in time but the power is enough to move the train as they release, before it stops itself perhaps? Thanks for your help.
NSEWonderer
5 Dec 2020
Are you describing a) a train stopping at a red signal, then proceeding once the signal clears (normal operation), or b) a train routinely passing a red signal (big problems)?
Or has the train actually been the one to activate the red by way of normal passage by it.
Liam L
19 Jun 2020
Sounds like to me that the train has proceeded through the signal and trasky has updated the train has moved into the next block section then the 730s 'throw a hissy' as I like to describe it and the brakes bring the train to a stop
However trasky isn't the greatest when it comes to relibity when it comes to showing signal aspects. Opentimetrains is often far superior.
Class 323221
14 Jun 2024
England
Sorry, I wasn't clear. A - Normal Operation
I think @Class 323221 actually meant heading away from a signal that was previously red and the train moves when it turns to proceed?
Yep, this is what I meant.
It was definitely a red signal. Crew also announce this. I don't recall it happening as frequently as at stations, but I haven't been stopped at danger as much as at stations.
To clarify - The signal was definitely at danger. The train proceeds through it once the signal goes to clear. I am definitely sure.
pompeyfan
24 Jan 2012
Could it be that because the signal is restrictive after stepping up from red, drivers are only taking a low power setting and that’s why the holding brake is sticking? Same would apply for platforms with low speed departures like Birmingham New Street etc etc.
JLX5
4 Jun 2020
West Midlands
It happens even when taking full power straight away.
