67 018 on the Shropshires
TGVDUDE
1 Jan 2009
Cheltenham
Hey people, does anyone know when Keith Heller is due off the duty, or is it taken off at random?
Chester025
29 Jun 2008
Currently working 1127 Wrexham - Marylebone, running 25 late due to a wheel slip fault. Should come back out of London on the 1833.
matt
30 Jun 2005
Rugby
thanks but do you know a final date. will it always run the 11:27 & 18:33?
I suspect it will run until the Wrexham and Shropshire 67 (67015 I believe) is back in action. It won't work the same services each day as for example yesterday it started on the 05:10 from Wrexham
Chester025
29 Jun 2008
As mentioned above it'll be different every day. If it's out tomorrow it should work the 0723 Wrexham - Marylebone and 1630 Marylebone - Wrexham.
TDK
19 Apr 2008
Crewe
If it's a wheel slip fault I doubt it will be on the 18.33, they may swap it out with 013 as wheel slip faults usually take a while to fix. You never know though they may be able to fix it. If it was on the 11.27 it would normally return on the 16.30 off Marylebone not the 18.33, the 18.33 is booked 67014 I belive.
If it's on the 07.23 it will form the 18.33 not the 16.30 I belive
barrykas
19 Sep 2006
Today 018 worked 1J80 (07:33 ex-Marylebone), which terminated at Shrewsbury 24 minutes down; 1P33 (11:27 ex-Wrexham, started from Shrewsbury), which terminated at Marylebone 33 minutes late; and 1J83 (16:30 ex-Marylebone), which terminated at Wrexham 28 minutes late.
Reports from Drivers that they couldn't get much over 40mph out of the loco!
craig87034
21 Oct 2009
In theory if 18 went back on 1J83 1630 Marylebone-Wrexham yesterday it should be on 1P01 0510 Wrexham-Marylebone/1J82 1120 Marylebone-Wrexham/1P33 1525 Wrexham-marylebone today
TDK
19 Apr 2008
Crewe
It was replaced by I think 015 this morning and take home for repairs
Dampflok
22 Sep 2009
Haddenham, Bucks
A few photos of 67018 on the Wrexham trains, starting here:
http://www.geoff-plumb.fotopic.net/p63350820.html
All seemed well on the first day (Wednesday) and it passed through Haddenham more or less on time whilst working 1J80 on Thursday, but it looks like the rot set in soon after that. Had it stuck to the diagram it would most probably have been on 1P01 this morning, but this was worked by 67014 and 1P03 was worked by 67015, which was the loco temporarily replaced by 67018.
I understand that 67018 is now back at Crewe for attention...
Cheers, Geoff
didcot
1 Dec 2008
Back again!
Working 14.04 Banbury -Marylebone today
Only about 8 mins down
37401
12 Nov 2008
On hire all week, first worked on Sat, today its out on the 1127 off Wrexham and 1630 off London, no ideas what it will work tomorrow, but Friday it should be the same as Today and Monday
Had a great run off it yesterday and a good laugh with some new faces and staff
http://rusty-264.fotopic.net/c1885577.html
TDK
19 Apr 2008
Crewe
The 07.23 usually forms the 18.30 from Marylebone, the 16.30 is usually the return fron the 11.27 off Wrexham
37401
12 Nov 2008
Aye swaps can and will happen though as it did for me tuesday, it worked the 0510 1120 and 1525, just as I wished, it should work those services again tomorrow but not sure what its doing today, been told it should be on the 1630 so another diagram swap has happened
TDK
19 Apr 2008
Crewe
Fridays normally see a swap as there is the extra train.
37401
12 Nov 2008
Yeah, tbh its got to come off soon so it makes sence to do the swap so it can come off the stock on sat, will only know if its doing the 1120 off london and such at about 0900 in the moring, but as I say ive been told its swapped today and its working (well will work) the 1630 off London
it worked the 1830 off "Fundon" today, TDK please tell me it'll work 1P01 1J82 and 1P33 tomorrow?
TDK
19 Apr 2008
Crewe
Yes according to our fitter tonight it will be on that diagram, I am on the 15.25 1P33 on it tomorrow.
craig87034
21 Oct 2009
WSMR today
67010 Wembley
67012 1J80 0733 Marylebone-Wrexham
67013 1P03 0723 Wrexham-Marylebone
67014 Crewe on exam
67015 Wembley
67018 1P01 0510 Wrexham-Marylebone
TDK
19 Apr 2008
Crewe
WSMR today
67010 Wembley
67014 Crewe on exam
67015 Wembley
67010 may form 1J89 to Shrewsbury tonight then and then 1P02 tomorrow if all goes well. So 018 is going back to DBS very soon I would imagine, then again 67018 may be sent back to Shrewsbury and 010 worked tomorrow. However there is a slim chance 010 will be put on 1J84 and 018 taken off, the plot thickens, it makes no ods to me what loco is on what :)
6 Jul 2009
WSMR today
67010 Wembley
67014 Crewe on exam
67015 Wembley
67010 actually at Bescot. It has an ongoing problem that DB are investigating and it is on its way back to Toton for further tests apparently. So likely 67018 will stay around until 67010 is fixed.
67014 will be on its way light to Wembley tonight to form first one off Marylebone for the morning and last arrival at London tonight will be turn around to form the 20.03.
