60+ oyster misuse
StaticKiwi763
7 Feb 2026
london
Hi everyone
I would like some advise in relation to 60+ Oyster card confiscation.
I got caught using my mums 60+ oyster and I have received the verification letter from TfL asking for my response
The letter was posted to my old address and only found out about it 2 days ago. I have therefore lost some time. Do you think it’s worthwhile asking for an extension or I should just go ahead and reply to the letter?
I know what I did was wrong, I’ve had sleepless nights about this. I am really worried and hope I would not be prosecuted. Any advise is much appreciated please
jfollows
26 Feb 2011
Wilmslow
The bad news is that TfL almost always prosecutes for this offence.
I think you should just reply, and there are plenty of similar cases documented here which can help you.
There is very limited evidence that using a solicitor might avoid prosecution, but it will cost you ££££ and there is no guarantee of a different outcome.
Fawkes Cat
8 May 2017
Just to add a little: assuming that you plead (or are found) guilty, you will of course face a punishment. But that punishment will be a fine (and there will also be court and prosecution costs, and compensation to TfL, and so on). So it will be expensive - but you won't go to prison.
StaticKiwi763
7 Feb 2026
london
Thank you all for your replies
Just to clarify the prosecution leads to a criminal record? Would my employer be notified ?
Would it be possible for me to paste my draft response for you to have a read please
SuspectUsual
11 Jul 2018
Your prosecution would be a matter of public record but I don't believe the courts directly notify employers. My advice would be for you to check your contract of employment and if that says you should tell them if you're convicted, tell them. Often in situations like this people can get in more trouble for not following the required procedure afterwards rather than what is essentially a pretty low-level bit of offending
Yes, post your draft and people will be happy to comment
z444z
17 Apr 2022
Yes absolutely! Do read through the TfL prosecutions policy, linked in a previous post. Specifically section 8.2. Any mitigation needs to be based on factors in section 8.2 to have a chance at being successful.
Fawkes Cat
8 May 2017
I don't think notification is automatic. But if the court had to collect your fine from your wages, inevitably your employer would find out.
You will also need to check what your contract of employment says: if it requires you to tell your employer about a conviction (or even about being taken to court - some contracts do that) then you will need to do so. Otherwise you could well be sacked - not for the fare dodging, but for breaching the terms of your employment: your employer might well say to themselves 'if they can't be trusted to follow that rule, what other rules might they break?'
If you're in a regulated profession (maybe health care, teaching, the law, accountancy - and there are others) you should also check what your regulator needs to know.
If you are a member of a union at work, it's a good idea to go and talk to a rep: they should be able to tell you what really happens at your workplace.
jfollows
26 Feb 2011
Wilmslow
Prosecution will lead to a criminal record, yes.
Of a fairly minor variety, perhaps, but that’s easy for me to say.
You need to check its implications on you and your employment.
StaticKiwi763
7 Feb 2026
london
Thank you all for clarifying. I don’t have any mitigating circumstance. I hust have to accept it.
Do I include that my address in the letter was wrong.
Please find below my response
  • TFL Response.pdf
jfollows
26 Feb 2011
Wilmslow
I don’t see a problem with your proposed response and, yes, you should correct your address as part of it.
Please consider letting us know what happens, even if it’s not the outcome you want. It will help us to give better advice in future.
z444z
17 Apr 2022
I’d remove the word “reasonable” in relation to administrative costs. TfL don’t settle but if by a miracle they consider doing so you want it to be clear that you’ll pay whatever number they give you.
Doesn’t hurt to correct the address yes.
StaticKiwi763
7 Feb 2026
london
Thank you. I’ll remove that, include my address and send it.
Silly question but do you advise sending it as an attachment or just as an email
WesternLancer
12 Apr 2019
Important to correct your address in order to avoid tho gs like court related documents not reaching you.
It’s not in your interests to miss any communication about any of this at all.
StaticKiwi763
7 Feb 2026
london
Hi all.
I’m back with another question. Does anyone know how long it takes to hear back? It’s been over 2 months and I’ve still not gotten back a response from TfL
jfollows
26 Feb 2011
Wilmslow
Hi all.
Normal.
If they prosecute, they have to bring the case to the court within 6 months of the alleged offence.
They are likely to do so.
MotCO
25 Aug 2014
Is it possible, despite including an amended address, that their response has gone to your old address? Can you still collect post from your old address?
island
30 Dec 2010
TfL normally prosecutes under section 17 of their Byelaws, which is a non-recordable offence.
Not automatically. However it is usual in TfL cases for an attachment of earnings to be issued for fine, surcharge, compensation, and costs, unless you advise the court that you can and will pay these within 7 days.
StaticKiwi763
7 Feb 2026
london
Hi all, I have received the court summons. The charge is Byelaw 17(1) of the Transport for London Railway Byelaws, and I'm to plead guilty or not guilty. It also says I can consult legal representative. Just wondering if anyone knows of any reputable solicitors I can contact?
jfollows
26 Feb 2011
Wilmslow
If you search the forum for “solicitor” you will find many posts, such as
If you are going to plead guilty you may want to ask yourself whether the cost of a solicitor is worth it, but obviously it’s your call.
The list above is a list of solicitors whom we know to have been engaged in similar cases in the past, but of course this is not a specific recommendation for any of them.
You may find posts referring to specific solicitors also if you search for them.
