5x Class 153 conversion to bike and baggage vans for Scotrail
You can't though, not without a bundle of mods to the inner ends of the 156s since they were changed from BSI to bar inner couplings. I'm sure this was mentioned upthread.
Not in the middle of the unit, in the middle of the formation. Are Corrour's platforms shorter than 3-car?
Edit: ah, yes, they are. Sorry. Perhaps passengers for Corrour (there aren't likely to be thousands) would have to use the regular bike spaces in the 156.
fgwrich
15 Apr 2009
Hampshire
Will these 153s have any seats?
The plan is that they will be half seats & half bike / ski spaces. They might re-use the Richmonds inherited from FGW or replace them with the now standard ironing board from Fansia.
ScotRail158725
27 Nov 2018
he means whole 156 unit-153-another whole 156, when people say in the middle regarding this they mean between the two 156s not in an actual unit
Wilts Wanderer
21 Nov 2016
153s have the exact same bogie as 156s, so I don't see why ride would be an issue. The window sills are high though, that could be a slight issue.
My understanding (not from first hand engineering experience I’ll hasten to add) is that the 153s have always struggled to maintain air pressure as they only have compressor. As all other Sprinters have at least two compressors and air pressure is a continuous line, one slightly suspect compressor would be ‘carried’ by the other contributing a bit more. BR of course did the 153 conversion as cheaply as possible and elected to avoid the expense of installing a second compressor. The poor air pressure is evident at the slow rate of brake release, often resulting in a squeal when initially starting from rest and a poor rate of initial acceleration.
The point I’m coming to is that running alone, the air suspension also has a tendency to be a bit low, which means you get less damping when the track is bumpy. Presumably that means when running in multiple things are a bit better, so hopefully the jointed track on the WHL won’t compromise things too much. The low linespeed will probably mean it is tolerable at least.
hexagon789
2 Sep 2016
I can understand the theory but you do still have the primary suspension as well which I believe actually does the damping, could be wrong I'm sure someone can confirm, but if the known air pressure issues with 153s do cause ride issues then it could be a bit lumpy on the WHL.
There is some 70mph running and you can do 60 most of the way from Cowlairs to Craigendoran. Hopefully it's still acceptable enough, we wouldn't want the punters spilling their tea now!
SteveyBee131
28 Oct 2017
Grimsby Town
I've been on several lone 153s on jointed track over the years and never experienced a bad ride. Certainly comparable to any other Sprinter so I wouldn't worry. I have noticed the slow brake release in comparison to other Sprinters that you mention, though I couldn't say if it's any better when they run in multiple.
HLE
27 Dec 2013
The air system on a 153 can be bad for small air leaks. Brake release can take an age, but it varies between units.
ScottDarg
27 Apr 2017
South Lanarkshire
One of the 3 currently undergoing conversion (305, 370 or 377) has appeared outside of the shed at Brodie Engineering this evening. It's been painted in the base ScotRail blue with silver doors but has yet to have things like vinyls (incl. numbers), light clusters and gangway doors re-fitted.
No view through the windows so whether anything has been fitted inside is unknown.
ScottDarg
27 Apr 2017
South Lanarkshire
common sense tells you its 153380, 153305/370/373/377/380 all came up from GWR to Northern on short term lease and scotrail were due 5.
Only if you keep track of stuff like this - which a lot of people don't so "common sense tells you" is poor word choice and comes across as a bit cheeky.
Thanks for confirming anyway.
Azzy49
4 May 2020
Dundee
I completely understand, comes across very mild and cheeky for one simple mistaken identifiction of a class 153
Steven_G
5 Mar 2018
Does anyone have any news of these coming out of Brodies? Reads in the thread that all the units are there being worked on but are we near the stage of one being released back to Scotrail?
Scotrail might be in no rush as demand plummeted but still, would be good to see these get in service.
Azzy49
4 May 2020
Dundee
I agree with your Point of might not be necessary to see them and get them into Service but would be nice to see the ready. On a Google Images Pic. A Class 153 is painted in a Debranded Scotrail Blue. That was a whiLe back though but haven't heard anything since.
