5x Class 153 conversion to bike and baggage vans for Scotrail
scotraildriver
15 Jun 2009
An 8 car set comes from Corkerhill on nightshift. 3x156 then form the 6.15 to Alloa and return then form the 08.21 WHL service.
CM
28 Dec 2010
I was under the impression that the inner couplings of the 156 were BSI couplers as per the outer couplers but without the air/electrical connections. I've yet to see photographic evidence to suggest otherwise.
Wst71Pa2
1 May 2018
I know some of the 158's are such (semi permanent) and some are rigid bar. I think 156's are he same. Another reason they were never going inside.
hexagon789
2 Sep 2016
I thought that too, certainly that was how it was originally - from May 1989 to May 1990 BR ScotRail reformed Inverness sets as 3-cars for use on Aberdeen-Inverness and in the summers of 1989 & 1992 reformed Corkerhill sets as 3-car for use on the West Highland, running two 3-car sets to Crianlarich and splitting there to run 3 coaches to Oban or Fort William/Mallaig.
James James
29 Jan 2018
I’ve no idea why this myth about them going in the middle of sets is being repeated despite the evidence to the contrary.
Rather than being a myth... could this just be a miscommunication?
156 (2-cars)+153+ 156 (2-cars) - that's a 153 coupled in the middle of sets of 156's. (But no 153 in the middle of a single 156.)
(I'm just speculating here of course...)
TheEdge
29 Nov 2012
Norwich
The physical coupling mechanism is similar but not identical to a normal BSI, they are bolted together for example. So they can't be just coupled to a normal BSI.
JModulo
17 Nov 2013
67A
I believe they are as they used to half 156s to make a 3 car 156 on the WHL
http://dysgraphyk.madasafish.com/156/class156_misformed.htm
As already stated a good few times now in this thread, the original BSIs have been / in process of being removed and changed to bolt couplings with air hoses and electrical jumpers.
Failed Unit
26 Jan 2009
Central Belt
You'll have to fit RETB in order for them to lead.
They have had RETB fitted to them in the past - when they we operated by central trains. The often operated in mid-wales (either solo or in pairs).
I remember a Saturday working from Aberystwth - Lincoln back in CT days that was a solo 153 so it must have had RETB (unless they used mobile units)
CM
28 Dec 2010
But I'm pretty sure no physical evidence of this work has actually been provided, not that I can find anyway.
LowLevel
26 Oct 2013
To be fair not many people bother taking photos of the underside of the corridor connection :p:oops:
I spend half my life on 156s and 158s and can cheerfully assure that all of ours have had their within set BSI replaced with a bar.
Mathieu
11 Jul 2016
Oban
Speaking with the guard working the 16:11 OBN - GLQ, the 153s will not be sandwiched as the owners of the 156 will not allow their units to be separated
big all
23 Sep 2018
redhill
a bit more information needed
special operating conditions will override unrestricted fully variable use
in general no restrictions will apply as it will be very restrictive to easy day to day activity requiring often fairly randon shunting and movements
Highlandspring
14 Oct 2017
Good night at the pub then?
Class 170101
1 Mar 2014
Given how utterly dead the 20.36 is I would seriously doubt it. The most passengers I've ever had on that train in the middle of summer was 13. It would also result in an additional unit overnighting in Oban to do what in the morning? The 05.20 certainly doesn't warrant a 4 car. Despite claims of overcrowding on forums such as this, the only train with real issues is the 12.11 from Oban. The Fort William is rarely full and I've never seen standing passengers on a northbound service, unless the train is short formed or one cancelled.
The 18:23 is always packed full of people returning to Oban after a day out in Glasgow. Although the 20:36 may be quiet I would say it’s a fair assumption that if there was a ~20:30 service from Glasgow to Oban it would have a decent amount of people on board
I would say that even heading to the sticks a 20:36 Glasgow to Oban service would have more people than the 20:36 from Oban to Glasgow.
GrimShady
13 Dec 2016
The WHL timetable is about to undergo a revamp which may result in seperate portions to Oban and Fort William. The 153s cannot be added to the busiest services at present as they run 6 car Glasgow to Crianlarich which is the maximum permitted. The 12.11 from Oban is one of the most overcrowded so would be a good candidate for a 153, but would need to run to Queen St without joining. The 153s will NOT be in the middle of a 156, the 156s all have permanent bar couplings so would need major work and would remove any flexibility. They will be added and removed as required. They will be used exclusively on Oban services initially then Kyle and Far North routes.
Surprisingly none running to Fort William.
jopsuk
13 May 2008
I'd have thought the bike carrying capacity would have been most use on Fort William services
LOL The Irony
29 Jul 2017
Chinatown, New York
So fitting a 153 with a vista dome observation lounge is a non starter then?
At one point, some ScotRail 156's were going to be heavily refurbished and have windows fitted in the lower bodyside. The seating would then be changed to a lounge style. I believe they were to be used on routes around the highlands.
OmniCity999
30 Jan 2018
April fools was yesterday...
Journeyman
16 Apr 2014
You say that but it was a genuine plan by Angel Trains (I think) a few years back.
Yup, I remember seeing a range of proposals, some of which were quite radical. One of the best featured seats with very large amounts of luggage space between them. Can't find any examples online right now, though.
LOL The Irony
29 Jul 2017
Chinatown, New York
Indeed they were. I couldn't see the windows in the lower bodyside becoming reality, maybe the windows going upwards a bit.
61653 HTAFC
18 Dec 2012
Lower windows would be easier on the 153s than 156s... just remove a panel and replace it with a new one, then rivet it back in! ;)
