I may of read this comment wrong but they are GM engined?
NXEC have looked into using 57/3's for rescues.
I love them as they do a lot more for the image of the British rail industry considering that a company can take a British built loco then take it in alter it refurbish it and hey presto it's good enough for even a company like virgin at the current rate we will have class 57 doing rescues for the following
Virgin currently use them.
NXEA Have just awarded DRS a contract for Thunderbird duties so they are lieley to use 57's.
FGW currently use them.
So from a professional standard they are good both down on paper and out in the field but if we want to talk about enthusiast value well there basically a class 47 that sounds different and actually works but seriously these lot are very hard workers and seriously know how to get it done.
And isn't it something to note that they took a type four which had defiantly seen better days and turned it into a reliable type 5 that is beginning to be sort after.
they use the 47 bodies killing off a 47
This is a bad thing because...?![]()
Anglia drivers only sign class 47s. Also, the DRS 57/0s do not have ETH, so would be unlikely to appear on an anglia thunderbird turn.NXEA Have just awarded DRS a contract for Thunderbird duties so they are lieley to use 57's.
They are just a 47 renumbered (and re-engined),that is all.
I love them as they do a lot more for the image of the British rail industry considering that a company can take a British built loco then take it in alter it refurbish it and hey presto it's good enough for even a company like virgin at the current rate we will have class 57 doing rescues for the following .
better as a 47...
No, IMHO the reason FGW 57/6s fail so often is
A. They aren't properly looked after
B. They are out working nearly every day.
Do you really know DRS will use 57s on them or are you stabbing in the dark? I really highly doubt they will, Don't NXEA Men sign 47s so common sense would be to use 47s.....
FGW Currently use them? And they're really reliable aren't they.....
No option for a 'No preference' opinion?
