Considering you only needed 7 185s, to score 4 of them in one day is a exceptional performance! I too need 185112, although I have a feeling you'll get it way before me. 144014 is also required here, hmm maybe I should get north again on my next bash...
I was pretty pleased with the 185s, no doubt about that.
No festering involved, either.
It was straight off one and onto the next, which was nice.
That winning streak at the end must have been brilliant! Sounds like a cracking day out there! 144014 is my last 144 required for sight!
144010 was my last one for sight, way back in the 80s. I remember that number 10 was either delivered late or developed a major fault very soon after arriving and so was taken away for several months.
Sounded like a good day, I will keep that Tram & Train rover in mind when I hit Manchester to do metrolink stuff, mainly to head to the airport/Rochdale by train and come back via tram
Aye, it's very good. Just remember that this ticket has the Northern peak restrictions, so it's tram only between four and six thirty (or whatever it is).
Productive day out, the Dez's certainly dropped nicely for you.
They certainly did, especially when you consider that I only scored two in the whole of 2015!
2014 only got me four new ones, so I've scored the same number so far this year as I did in the previous two combined.
A most productive day indeed, and an enjoyable read too.
Out of the dud units from your day out, I still need 155347 (just this and 155343 needed to clear the class), 156425, 156489 and 185145 for haulage. I need two of your required 185s (185102 and 185112) as well, hopefully it won't be too long before we can tick them off our lists!
Thanks. I get 155s regularly on my commute. Sadly 156s no longer appear around Bradford.
I concur with the above, certainly done well there, its nice when stuff drops like that. Gives you that, well I'm an half glad I done that today, feeling. Did Mrs 13, get rewarded with flowers.
Just think how many more you mght get if you done a North East Round Robin
(ducks for cover)
Mrs 13 got her reward with the reclining sofa she bought from the British Heart Foundation whilst I was over there!
A mighty fine read there. Well done on hammering those Transpennine needs. Four from seven 185s is definitely good going. Let's hope that the Railway Gods are having an equally good day when it comes to my rounding up my last remaining 185s.
With all due respect to those folk who are now bagging 319/3s up north, I was quite happy to see them leave my neck of the woods - I'd well and truly got fed up of them as I'd had most of them when they were brand new as 3191xx and then suffered them constantly thereafter, particularly when they had their first class seating ripped out and became 3193xx units.
Cheers.
Future Manchester moves will be based around airport trips as they tend to have seats available, so are more relaxed than the usual Stockport wedge-fest.
Hopefully the remaining three 185s will drop on airport turns and I can forget about them
My monthly annual leave day for May was on Friday the 13th, would it prove to be unlucky?
I was London bound and started in my traditional fashion by driving to Wakefield and leaving my car in the car park adjacent to Westgate station.
Prior to this move I had three 91s that were in the “still below 500 miles, never mind a thousand” club so I was pleased to see one of the three, 91131, was to be my power South.
Not only was 91131 below five hundred miles, it was actually my lowest member of the class, sitting on a pathetic 254 and a bit miles.
Even after a run to London it remains in that ignominious club, although no longer at the bottom of the pile.
The run down, on a fairly quiet train, was punctuated by me scoring 66772 for sight at Peterborough.
Due to the fact that I’d left it fairly late to book there had been no cheap tickets on the 07.13 from Wakefield and so I had gone on the 07.28.
This meant that I arrived in the capital a little too late for the pair of 387s that I’ve covered from St Pancras previously.
Nevertheless, St Pancras was where I headed.
I had no plan and was just making it up as I went along.
Dud pairing 319002 and 319004 arrived at the same time I did and so I jumped aboard in preference to hanging around and did a quick bit of research on the move.
I elected to bail at Blackfriars as I had discovered an interesting service was just behind and an idea was formulating.
Dud 319220 pulled in with the day’s first winner,
319439 on the rear.
These were done to my first new station of the day,
Catford.
Sadly I had some issues that I was unaware of at this point; I had located my camera, which I couldn’t find prior to my Manchester trip, a few days before and had been experimenting with the settings.
Evidently I had pressed a button marked “make all my photos sh*t” and it later turned out that this button had done exactly that.
Of the ten pictures I took before I discovered the problem two were completely unsalvageable and so were binned but after
a lot of work with Photoscape I managed to make half a dozen just about good enough to keep for my records, but still way short of being fit for public consumption.
Only two could be improved enough to be included in this report although even then I’m disappointed with them, so please forgive the sub-standard quality of the next two pics.
319439 leaves Catford:
EMU 319439_2016.05.13_Catford by
Phil Wood, on Flickr
Now it was a short stroll over to
Catford Bridge for my next run.
I had, on a previous trip, done the end bit of the Hayes line from Elmers End after getting off a tram.
Now seemed like as good a time as any to fill in the missing bit of track.
465189 and
465049 appeared after a short wait and I did them to
West Wickham.
I had no choice but to hang around for the same pair coming back, naturally travelling in the set that I hadn’t used going up.
465049 leads coming back:
EMU 465049_2016.05.13_2_West Wickham by
Shortly after leaving I saw a pair of 376s heading to Hayes and identified them as two requirements and so decided to bail at
New Beckingham for something back to meet them.
Winner
465167 and dud 465048 powered me for the half mile run to
Clock House.
376009 and
376003 produced as anticipated and I took these through to Charing Cross.
The short leap I’d done between New Beckingham and Clock House bugged me and I wanted to nudge 465167 over a mile and so I re-boarded the 376s, sitting in 376009 this time, and did these to Waterloo East in order to pick up the pair.
I did the two 465s into Charing Cross and then back out to Waterloo East as I fancied something different.
I mooched over to the main station, keeping an eye out for pigeons, something that I do following an incident there several years ago when one of them had got over its constipation right on top of my head.
The first of a hatful of 455s were then had, with
5856 and
5716 being sampled to
Chessington North.
The same pair, again with me sitting in the set I hadn’t done coming out, were taken back as far as Wimbledon and another change of scenery.
When the 455s had pulled out of Waterloo I had viewed a service preparing to leave with a couple of 456s on the front.
I couldn’t identify them but had worked out a plan, utilising Real Time Trains, to cover them nevertheless.
I had a bit of time to kill before they came back from Woking and so it was tram
2557 out to
Merton Park and dud 2542 back.
When the train I was waiting for arrived I was happy to see doyen of the class
456001 was the middle unit in a set completed by
5722 and dud 456014.
I spotted another unidentified pair of 456s and, once again using RTT figured out I could get them from a required station by using the same rake I’d arrived at Waterloo on.
I sat in 5722, which obviously was still with 456014 and 456001, out to Clapham Junction and then boarded
5873 and
5862, which I took to
Berrylands and my appointment with more groovy 456ers.
It was while I was waiting here that I found out about my only bit of bad luck of the day.
I discovered that all the photos I had so far were ridiculously bright, with some looking blurred as well.
At least I discovered it in time to change things so that I could get some half decent photo records of the day from here on in.
The train I had gone for arrived, with
5707 on the front, dud 456016 in the middle and
456020 on the rear.
These were taken through to Waterloo and I began to think about the most productive way to head back to Kings Cross.
Rush hour was building up and I wanted to be away from the worst of it so left on double winners
5720 and
5912.
Once again I spotted a pair of 456s, with a definite requirement on the country end, as my train pulled out and so I bailed at Clapham Junction in order to pick them up a few minutes later.
Sure enough
456013 arrived after a short wait and I boarded without checking what the other units in the set were, I didn’t have time but I don’t like doing that as I’ve been known to forget to check when I get off and wander away before realising too late.
I needn’t have worried this time as
Stoneleigh is an island platform so I didn’t have to go anywhere.
Both the accompanying units turned out to be new,
456007 and
5740.
Winner
5715, my tenth and final new 455 of the day, appeared with 5739 and I took these back to Wimbledon.
It was now back to the tram network and
2547.
I had picked a suitable Thameslink service to do from East Croydon to St Pancras but had plenty of time so decided to bail at a new shack in order to rope in the tram behind, which I knew to be required.
Phipps Bridge was the place I elected to bail and it was tram
2558 from there to East Croydon.
2547 heading away from Phipps Bridge with one of the day’s other winners, 2557, standing in the platform at Belgrave Walk:
Croydon Tram 2547_2016.05.13_2_Phipps Bridge_& 2557 by
I was heading back but I wasn’t finished with the winners just yet.
377516, partnered by
377506, was what appeared for the cross London stagger.
My journey home also produced something of great interest to me.
It was “Flying Scotsman” liveried 91101.
Another one of the three sub five hundred mile members of the class, nice one.
I’d last had 91101 in August 2004!
Isn’t there a steam loco called Flying Scotsman?:
91101_2016.05.14_2_Kings Cross by
Unlike 91131 in the morning, 91101 has now left the “still below 500 miles, never mind a thousand” club
My lowest mileage 91 is now 91120 on 263.76 miles, so fingers crossed that appears on a future trip to the capital.
I last had that on the 2nd of July 2003, so another run on it is well overdue.
So, in conclusion an excellent day with no less than twenty-five new haulages and ten new shacks, not to mention two of my three most wanted 91s.
Another Friday the 13th, another successful move - proving conclusively that talk of bad luck is just superstitious nonsense.
