4G severn tunnel?
mrmartin
17 Dec 2012
Interesting I've noticed I'm getting some signal from EE in the severn tunnel. LTE800 5MHz. Is this from a leaky feeder ESN or some freaky ability for the signal to propagate down the tunnel?
Torfaen
8 Dec 2025
Pontypool
I first noticed the 4G signal in the Severn Tunnel a couple of months back. There definitely never used to be a mobile signal (the catering trolley would park up while in the tunnel because their card machine didn't work without a connection). If a leaky feeder has been installed I'm surprised there hasn't been any publicity for it. Very welcome, all the same.
hexagon789
2 Sep 2016
ADComms assisted Network Rail in installing six mobile repeaters in the Severn Tunnel some months back.
Four major telecoms providers also had input in the project.
hexagon789
2 Sep 2016
Would those be the four national real (not virtual) mobile networks in the UK (O2, EE, Vodaphone and Three)? or something else?
I can't find the article on AdComms website now, but I think those were indeed the four.
plugwash
29 May 2015
Searching google for adcom severn tunnel pulled up a link to https://adcomms.ltd/project/severn-tunnel/ the page seems to have disappeared off their website, but archive.org has it. Seems the article is 5 years old,
mrmartin
17 Dec 2012
Yeah FWIW I'm _not_ on EE, it just move over to it cos there was no other signal, I couldn't get any data.
Very cool if all the operators are going to be able to use it, it's a really bad blackspot.
Torfaen
8 Dec 2025
Pontypool
No mobile signal in the Severn Tunnel the last few times I have travelled through it. Has the damp salty environment corroded the electronics?
Torfaen
8 Dec 2025
Pontypool
ESN = Emergency Services Network?
5MHz should perhaps say 5G? LTE800 is the 800MHz band. I'm not sure 5MHz would propagate well along a tunnel when the wavelength is around 10x the tunnel diameter.
stuving
26 Jan 2017
I take 5 MHz to be the radio channel bandwidth - and 5 MHz is the minimum, the same as in 3G. This radio "bandwidth" really is the width of a radio band, not a data capacity (bit rate), but it is a factor limiting the data capacity.
vicbury
17 Mar 2012
Lydney
On my work phone, which is on Vodafone, I get full signal through the Severn Tunnel, but no data. On my personal phone, which is on ID Mobile, so Three's network, I get nothing at all.
I assumed the signal was there for making emergency calls however data would be quite handy for tracking tight connections at Severn Tunnel Junction.
MrJeeves
28 Aug 2015
Burgess Hill
The Severn Tunnel has had mobile coverage for Emergency Services Network (ESN) since 2019, after ADComms was contracted by Network Rail Telecom to work with them and EE to modify the existing Severn Tunnel radio infrastructure by designing and installing a Neutral Host Distributed Antenna System.
This is not a repeater solution in the normal sense, but a neutral-host distributed antenna system (meaning it is not unique to any particular operator), with mobile network radios in a comms room on the English side of the tunnel, antennas found inside the tunnel, as well as an infill antenna on the English tunnel portal for better handover.
The application and ADComms website reference repeaters, but these are to rebroadcast the dedicated signal which is broadcast into the tunnel rather than to rebroadcast the signal from outside of the tunnel into the tunnel like you might see for an in-building "signal booster". This was done so that a replacement of the existing leaky feeder cable in the tunnel wasn't needed, and neither was installing a brand new cable just for this.
It used to be the case for many years that this coverage was only for ESN users, but EE customers could "sneakily" (unintentionally) roam onto this network if they were on a phone call prior to entering the tunnel. If they were not, the network would refuse them access to the ESN network.
Around September 2025, the solution was also enabled for EE's consumer network, and started broadcasting under their network identifier (PLMN) as well, so all their customers can now use it while travelling through the tunnel too.
The deployment should be 5 MHz paired UL/DL (FDD) of Band 20 800 MHz 4G LTE, as well as 20 MHz paired of Band 3 1800 MHz 4G LTE. My understanding is the 1800 MHz deployment is effectively unusable, though, with high error rate.
You can see further details in the planning application for the project:
There is no coverage for other mobile networks in the tunnel today. If people report seeing this, it's likely an error, the phone lying about having signal (common if you are connected to WiFi with WiFi Calling enabled), or the phone displaying the signal of another network to reflect that something is available for emergency calls which can be made on any network rather than the network you pay to use.
plugwash
29 May 2015
Not just "a" factor, but probably the single most important factor.
The shannon-hartley theorem defines the theoretical maximum capacity of a channel based on certain assumptions, it says.
C = B Log₂(S/N)
In practice this forumula tends to serve as an upper-limit for channel capacity. The logarithm in there means that improvements in SNR have relatively little impact on capacity, while improvements in channel bandwidth have a massive impact on capacity.
