4 wheel wagons still in use
tjlrailblue
20 Sep 2013
Which 4 wheel wagons are still in use?
I see that MEAs are used to carry sand
Also i have seen MFAs used for ballast and spoil
Are TTAs still used for aviation fuel? Anything else use them?
What is the code for the covered vans on Boston steel trains that are 4 wheel?
Presume still quite a few other 4 wheel wagons about but obviously far less common nowadays.
What other types are still going?
Tim
Ash Bridge
17 Mar 2014
Stockport
Tim
CDA China clay hoppers in Cornwall.
RichmondCommu
23 Feb 2010
Richmond, London
I often see four wheel long wheel base Cargo Waggons at Willesden whilst on their way to and from the West Midlands carrying mineral water to and from France. There are also four wheel cement bulk carriers still running around and these can often be seen at St Pancras Church Yard sidings.
fgwrich
15 Apr 2009
Hampshire
There's a handful of HEA Hoppers still in use by DBS on flows such as aggregate from Southampton Docks to Glasgow for B&Q. A handful of MEAs as you say still exist in occasional service too, along with plenty of MFA Coalfish, MTA, OBA, VBA and VDA remain in use for departmental and MOD use as well as the already mentioned CDAs still trundling around Cornwall. Don't think any TEA tanks are in use anymore following the cessation of the Fawley tanks, but there are at least two variations of the "CargoWaggen"s out there and the STVA Car Carrying wagons are also 4 wheeled.
ash39
8 Feb 2012
PGAs on the Middleton Towers sand are 4 wheeled.
jimm
6 Apr 2012
There are still a good few VGA vans in use on MoD trains operated by DB Schenker, which are a frequent sight at Didcot en route to and from the likes of Bicester and Kineton.
Freightliner is using TTAs to transport diesel to Ipswich fuelling point from Lindsey refinery. Scroll down to the pictures from Long Marston and Honeybourne taken June 15 at this link, captions contain info on the traffic http://petertandy.co.uk/class66.htm
The sliding hood steel carriers used from Boston Docks and on other flows such as South Wales to Round Oak may be short but have bogies due to the weight of the loads that they carry. TOPS classification is IHA, under the UIC system they are Sfhimmns
https://c1.staticflickr.com/9/8209/8188116449_6d80e5703c_b.jpg
andypops
31 Mar 2011
Also forgetting the SSA / POAs too - although even after being re-bodied a few years ago they are now in rag order.
dk1
2 Oct 2009
East Anglia
There seem less & less on the Mountsorrel LaFarge workings into East Anglia in the last few months. Only a couple on the Trowse today. As mentioned by ash39, still a full trainload on the WBB Minerals.
SpacePhoenix
18 Mar 2014
Don't know if any still exist but the LPG tankers that went along the SWML I think where four wheel
RichJF
2 Nov 2012
South London
Travelling through London Bridge while the works are on; you see a variety of 4 wheel wagons attached to the rear of the ballast/sleeper trains.
They are usually in EWS maroon/yellow livery with yellow axle covers.
I think these are the MTA & OBA series of wagons.
I sometimes see some in service behind 73's at Tonbridge when I'm around there.
tjlrailblue
20 Sep 2013
saw some vga vans used as barriers i think on a video on youtube
cheers for replies anyway. more still around than I thought!
Tim
GB
16 Nov 2008
Somewhere
Yes and no. IPA car carriers are four wheelers, but as they are also 'quad' wagons, they are on the one hand four wheelers and on the other 16 wheelers. 'One' wagon is actually made up of four, semi permanently coupled together. They are either the double deck cartics or the ones used on the Jaguar/Landrover traffic with the canvas sided 'hood'.
Then, just to confuse matters, you also have the open twin cartics for carrying vans etc, which again are semi permanently coupled and are either two four wheelers or one eight wheeler, depending on how you view them! On the outer ends they have conventional buffers and draw gear, but in between individual four wheelers in the quad, they only have one buffer on opposing corners.
Lol, I knew someone would be along with that technicality:lol:
