395 Olympic Javelin
Crompton Karl
14 Apr 2007
Kent
And what would the point be in replacing stock ideally suited for Semi fast services to the Airport with stock which was built for long runs at High speed? That would make no sense.
Karl :)
Gizmogle
28 Aug 2006
I'd have the 395 on the Buxton branch.
Walk down the train and you're at the next stop! :D hahah
8 Dec 2006
Costa Del Sheppey
There is rumour that SET are going to start doing Victoria - Sheerness - Dover services again from 2009. The rumoured stock is 395 as well, otherwise it will be Electrostars.
Not too sure how true this is mind you.
me123
9 Jul 2007
No expert here, but would the 395 be able to take advantage of the high speed on the Heathrow Lines?
Jordy
9 Jun 2005
WCML South
Its relatively short, and I highly doubt the speed is more than 100mph, which the Desiros can do anyway.
T
Tom
Guest
Top speed between Heathrow and London Padd is 125mph but not for far ...
If 395s do that Sheerness / Dover service, it will be out of St Pancras, not Victoria.
