387/2 diagrams
Andy1673
10 May 2019
If you mean Gatwick Express/Southern sets weekdays 21 set of 26 diagrammed. 14 sets work all Gatwick Express services Victoria to Brighton (1W/1M headcodes + 1A71 and 1D98/1U03) in various formations (4,8 or 12 car). Also 5 single set booked for East Coastway services between Brighton and Eastbourne/Hastings/Ore. Two more sets working morning peak Littlehampton to London Bridge and evening return.
Minstral25
10 Sep 2009
So stating southern have a shortage of units when they 5 of 26 387/2's on maintenance every day (19% of fleet) with 2 more just running for about 2 hours, then sitting on Selhurst all day. That seems excessive for maintenance on electric stock (although if someone can explain why its about right I'd be happy to learn - I am not an expert).
90% utilisation ought to be fairly normal for the Electrostar/Desiro generation of EMU. IIRC at one time SWT had a period with 42 x 444 diagrams, that’s 93% of 45 units.
Minstral25
10 Sep 2009
Yes, my memory says that at one time Southern had a 96% usage of units, so 81% suggest the 387/2's are not intensively used, which implies Southern have no need for extra stock as discussed on other threads as they have capacity and are not using it.
FGW_DID
23 Jun 2011
81D & 81E
No, not excessive at all. There'll be units on scheduled exams, component changes etc, plus when you account for the many varied reasons a unit can get failed for, it soon eats up the maintenance slots. Our 387s are broadly similar - 24 of 30 in use Mon - Fri which is 80%.
Magdalia
1 Jan 2022
The Fens
FCC class 365s were diagrammed 38 of 40 units in the weekday peaks, which was 95%.
Andy1673
10 May 2019
After withdrawal of the 455s and 313s Southern usage of its fleet is well. Weekdays diagrammed 25 of 28 377/3s, 30 of 34 377/6/7s, 137 of 154 377/1/2s and 21 of 26 387s - all similiar. If it would or will be requied Southern can add pair of 387s and three or four more 377s in booked (diagrammed) working. SWR has one case of similiar usage of its 444s - 41 of 45 and one case of more intensive usage for greater class 450s - 120 of 127 (on paper).
23 Nov 2015
The outlier of that is the 387s at around 80%. That is low for a modern EMU - you'd expect around 90% availability, or 23 units from 26.
