37901 - Eastleigh Works
TimboM
12 Apr 2016
The paper you can see is actually copies of the Transit Certificate issued by Colas for when it was moved - nothing to do with who owns it.
As to who does, doesn't seem very clear at the moment, but suggestions are either Europhoenix, Victa or Colas. Might well be more of a clue once it appears out of the paintshop at Eastleigh.
FOCTOC
23 Jun 2018
Its going to Europhonix, Colas have sold it on as not conforming to their fleet requirements.
Cowley
15 Apr 2016
Devon
Another question for those that know: How easy would it be to source parts for the engine fitted to 37901 these days?
Does it share many parts (i.e heads/injectors etc) with the same unit fitted to a class 60?
JKB
1 Oct 2018
I worked for Mirrlees on the Class 37/9 and Class 60 projects. I'm pretty sure we converted the heads on 901 and her three 6MB275T engined sisters to Class 60 spec when we did the F Exams at Doncaster. The injectors will be the same but I think the fuel pumps have slightly different elements. The governors, water pumps, oil pumps, turbochargers and intercoolers are completely different but as far as I can recall all the engine internals are interchangeable. The chap who owned 901 also had its original power unit but I don't know if he sold his stock of spares with the loco.
Spares common with the 8MB275T engines in the Class 60s will be available from MAN who now own Mirrlees (a sore point with me and plenty of others), plus an ex-Mirrlees chap has set up his own company in Stockport to work on the 60s with their current owners. I don't know for sure, but I expect he sells parts as well.
Cowley
15 Apr 2016
Devon
Excellent JKB. Thanks for that and welcome to the forum.
Was the Mirrlees power unit in the 37/9s fairly reliable? They always seemed to be out and about working when allocated to Canton without much time stopped for repairs.
I may of course have false memories from this time distance...
JKB
1 Oct 2018
Cheers Cowley.
I think it's fair to say that 37901-4 were pretty reliable. The biggest problems I can remember, and as you say, it's a long time ago, were with the radiators and silencers.The radiators were made by a company called Spirol Tube and supplied by Brush Traction who project managed the conversions. They seemed to be constantly leaking and I got sick of changing them. As far as I know they're still leaking!
The silencers were made by Gloster Saro and had to be a very complicated shape to fit in the available space, bearing in mind that standard 37s don't have silencers. They were made from Spanish stainless steel of dubious quality and cigarette paper thickness so they were very prone to cracking and blowing their stuffing all over the place. They were chucked out in the end and the loco's reverted to a straight-through exhaust.
The engines themselves were pretty good, the odd leak aside, and if Class 38 had gone ahead I think it would have had 6MB275T engines.
cclass
10 Dec 2018
Hi Guys took some photo's yesterday 17th December 37608 & 37901 both at Leicester there are also two others numbers not known
theblackwatch
15 Feb 2006
Interesting stuff there @JKB concerning the commonality of spares with Class 60s. Out of interest, do you know if the spares had a commonality with the engines that were fitted to 4 HST power cars (43167-170) in the mid-late 1980s as well?
43096
23 Nov 2015
There would have been very little commonality as the HST engines were the MB190, a high-speed engine running at 1500rpm, whereas the MB275 is a slow-speed engine running at 1,000rpm and designed for very different duty cycles.
